I need help.
I see, got you. Once that is cancelled I will go for that build you created. I'm sure they will be happy to hear that !
Aslong as your exspectations are that to get a better gaming experience in future you will need to get a dedicated graphics card just need to make that clear !!!! But this system is way better then your original ! And allows.you to upgrade in future
Jwm_1
If you do want to upgrade the graphics card in future do not lower the power supply on checkout itll recommend this to you to save money but you will need that psu to easily add a graphics card in future otherwise you will have to buy another power supply your more then welcome your workmates really helped you out there !!!!! In future when you come to upgrade the graphics card feel free to ask for advice again !!!!
Is that what you mean about the power supply?
Yes, that's just letting you know that in it's current configuration, you don't need the extra room on the PSU.
But you're not configuring it with the current power requirements in mind, you want to allow for upgrades in the future, so you can just disregard that message, it's not relevant.
Having a higher rated PSU does no harm, it doesn't affect what power is being used by the system, only what maximum power the system is able to draw. In fact, it's good practice to overspec the PSU within reason as it has to work less hard and leads to better stability and lower noise, better airflow in the case.
Jwm_1
AMD Ryzen 5 5600G Six Core CPU with Radeon™ Graphics (3.9GHz-4.4GHz/19MB CACHE/AM4)
ASUS® TUF GAMING B550-PLUS WiFi (DDR4, USB 3.2, 6Gb/s) - ARGB Ready!
STANDARD AMD CPU COOLER
NOT REQUIRED
Standard Build - Approximately 16 to 19 working days
Price: £1,082.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/hUraP9qa2h/
Could buy a graphics card in future to add to this system this is just one option
Would this set up work with the ryzen 7 5700G 8 core with radeon graphics
Here it is with the 5700G coming in at just under £1200
AMD Ryzen 7 5700G Eight Core CPU with Radeon™ Graphics (3.8GHz-4.6GHz/20MB CACHE/AM4)
NOT REQUIRED
Price: £1,199.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/2ZbXbUMGRE/
Jwm_1
Fair enough, just asking. My order got cancelled successfully so I'm just about to purchase the other one so I thought I might ask before hand
Steveyg
If you have an extra £100 you can throw at the build then a better CPU cooler would be recommended. One of the Corsair AIO's would be a great addition
Steveyg
Would that be instead of the 8 core? Or as well as?
Something like this, the 8 core 5700g will offer just barely an improvement over the 5600x. I think a better CPU cooler for the 5600x would be a much better path to take.
Corsair H100i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
NOT REQUIRED
Price: £1,217.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/fpycCxbp8b/
Steveyg
Solid build mate, you can slot a good GPU in there down the line and really bump the gaming experience
