Ashleyjames98
Hi guys,
So I've recently installed a RYZEN 7 3700X with a Wraith Prism Cooler set to low and the temps are all over the place! As I'm writing this, the lowest temp I've had is 41 degrees and the highest is 70 degrees whilst on Modern Warfare. Even with Modern Warfare playing, shouldn't temperatures be lower? If so, what can I do to reduce temps?
Many thanks
Many thanks
