Help with graphics card. Please help!
Will
So I finally got my new pc yaay!
But the bad thing is which I don't get is why the graphics suck. It's like playing a play station!
What's wrong with my graphics card? :(
Will
Any game, I installed The Sims 3 first and then I went and played Final Fantasy 14.
Michael89
Have you checked the NVidia site to see if there was a different recommended version anyway? The ones you have installed may be the ones from the CD?
Meds
When you say they "suck", what do you mean by this?
- Poor quality/resolution
- stuttering
- low frames per second
- artefacts
JSG10
Expert
To start simply, have you put the graphics settings for the games up to max and enabled all the options? Don't think sims3 has great gfx anyway and ffxiv make sure you run the config period first, you can't change gfx in game. Whack the resolution up and enable all options again. Don't forget to save.
Will
Poor quality/resolution is the problem. It's actually like playing a pc with no graphics card, I remember trying to play games on my old pc when I was a kid lol. But the performance is very good, no lag. If I can't fix the problem myself I will get someone to come over to see what they can do. If you guys can make a tutorial on how to max out the graphics card that will be great. Thank you!
Rakk
The Awesome
Many games have their own options for graphics settings, like what resolution you want and various other bits and pieces, each game will have it's own options and will need to be set separately.
Will
Drivers are already on the pc, maybe I should try updating them. If it helps, when I start the pc the motherboard I believe shows a message at the beginning "No any device found!" (i think).
Phoenix
It looks like your playing games with the onboard graphics, make sure that the GPU is connected inside then ensure that it's being used.
Rakk
The Awesome
Also make sure your monitor is connected to the graphics card rather then the onboard connector.
Will
It's connected through DVI cable. At first I was using the AVI able what came with the monitor.
Darko
uninstall nvidia drivers with driver sweeper. Restart you pc and then install drivers from the pcs cd. When you do that prolly ur pc will need restart again. If this wont fix it then update to the newest drivers.
Post here results.
Will
First I will update drivers see if it improves if not I will look inside pc before uninstalling them. I believe that Phoenix is right about it being run onboard graphics.
Kalisnoir
Super Star
Is the cable plugged into the very lowest DVI port? If not, your using your onboard. If you hadn't said no device found, I would of jumped to the conclusion that your running the game settings on a low resoloution.
Right click My Computer > Manage > Device Manager > Display Adapters.
What does it say?
