Yep, nothing new is showingAre you sure all updates are done? You have to keep pressing check for updates each time it completes a batch.
And also ensure that you install ALL OPTIONAL updatesAre you sure all updates are done? You have to keep pressing check for updates each time it completes a batch.
Thanks, all completeAnd also ensure that you install ALL OPTIONAL updates
Now go into disk management and you should see your other drives, they'll likely need initialising.Thanks, all complete
Thank you guys it's all working now 👍Now go into disk management and you should see your other drives, they'll likely need initialising.
