Just spoken to PCS and they will be sending out a single stick or RAM to swap with the faulty one.
I specifically questioned the call handler about having a matched pair and concerns about it running in dual channel.
He said that there wouldn't be any problems and the stick that is being sent out will be the same brand/size/mhz. So I guess I will check this RAM when it arrives and also check it in the program suggested for showing if the RAM is running dual channel or not.
Thanks again.
Thanks again.
