Help .. New Computer Doesnt recognise My Camcorder
Hi Ubuysa
I must confess I am a bit apprehensive as I have never opened a p.c up before, but I will, I will look online on what to do so I don't do anything wrong like static etc from fingers ??
I will see if if firewire card is, located properly .... but please could you explain what you mean about if drivers are installed ???????
Thank you for your help
Bob
Static can often be an issue when you're messing about inside a PC, some people seem to carry more of a static charge than others. Ideally you should get a wrist strap that keeps you earthed (most good computer shops have them). Alternatively you can leave the power cord plugged into the wall socket but switched off. This keeps the earth connection to the PC, by regularly touching the metal area of the power supply or case you will be earthing yourself and dissipating potentially dangerous static charges.
Opening the case is usually quite easy, if you tell us what case you have then those with the same case can tell you exactly how to open it. Inside you'll find the large motherboard, screwed down into the case, with a number of cards plugged into it. By tracing the wires back from the FireWire ports on the case you should be able to identify the FireWire card. It probably won't be very big and may be tucked away. Just see whether it is seated fully home, push it gently to see. To be completely sure you can pull it out and then push it back firmly (but gently). Also check that all cables and connectors are properly seated. It's not unusual to see connectors that are not plugged in anywhere, if you're not sure whether a connector should be plugged in and where it should go take some photos of the inside of your PC and post them on here.
Sometimes stuff does move in transit and it's not impossible that the FireWire card has become unseated (or one of the plugs has).
Drivers are items of specialised software that form the interface between the intricacies of the particular bit of hardware (like your FireWire port) and the standard interfaces of Windows. For most hardware a driver is required to be installed in order for the hardware to work properly (or at all). Drivers are written by the hardware vendors, all the appropriate drivers for your build will be on a CD that was supplied to you with the PC. I'm assuming that Windows was pre-installed? It's possible that PCS simply didn't install the FireWire driver, so you need to insert the driver CD disk you have (and you may have more than one) often they will auto-start and you'll see some sort of driver install program, you need to look for an option to install IEEE 1394 (or FireWire) drivers.
If you can't make head nor tail of your driver disks then call PCS, they will be able to talk you through exactly how to run whatever driver disks they sent you.
slimbob
Ubuysa thanks a million my friend !!!!!
First of all I would like to thank everyone who has kindly contributed to this thread and helped me so much.
Vanthus
Dogbot
Ubuysa
Boozad
Steaky360
Guys SORTED !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:yes:
I Pushed the card and it moved ever so slightly ..... I then put my p.c back together and started it up .... now the iee 1934 bus host is visible under device manager!!!!!
I plugged in my old Panasonic NVGS400 via firewire and hey presto my P.C recognised it and installed the drivers straight away ..... it works a dream!!! :yes:
Guys I am so happy !!!! Now I can carry on with my project using my Panasonic mini dv camcorder using windows movie maker 2.1 (don't laugh !!!!) I know it is old but I know how to use it and am very happy with it .
I am not very technical minded and it takes me a long time to learn new software (lol) !!!
Dogbot was on the right track at the start with a concern about the card not being located properly in my P.C as was everyone else too ....
Can I just say this forum is such a wonderful place and you are all so helpful .... I have made sure to add to all you rep scores ... It means so much to have you here for support and back up especially for us non technical people like me. Priceless!!
I will get back in touch with PCS and say there is no problem now ... these things happen and I was just a tad unlucky I feel .... I am very very happy with my brilliant new p.c !!! and now my old camcorder is working with it I am literally over moon !!!
I wlil say it one last time
THANK YOU EVERYONE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
All the very best to you all
Bob (On cloud 9)
P.s - Ubuysa your helpful advice about opening up my p.c was a huge help and has been copied and pasted for future reference !!!!
This has been good as at least now I know how to open up my P.c (lol) ! There's always a +
Great news. :)
Do tell PCS about the poorly inserted card, knowing about this may help them to stop somebody else having the same issue.
Thanks for the rep. :)
Oh...and extra rep to dogbot. ;)
slimbob
Hello
Yes I will but not in a moaning way just so they know etc ... I am very happy :yes:
Thank you again for your help sir
Best wishes
Bob
Rakk
The Awesome
It is of course possible that it was caused by a pothole somewhere en route (and lets face it there are a lot of potholes around), and no matter how well it was fitted it, things can get knocked out of place :(
slimbob
Thank you Dogsbot ..... indebted to you for pointing out the potential problem and helping me fix it .... Now I can carry on with my editing project !!!!!
Thank you Boozad for all your help and priceless advice too!!!!!!!
All the best to you both
Bob
Organground
Glad it's sorted. Under Device Manager my firewire shows up as IEEE 1394 and I use a ten year old Canon that was a competitor to your Panasonic so really no excuse not to be compatible. I use WinDV to copy from camcorder to hard drive, I have to connect the camcorder, open WinDV, press play on the camcorder then quickly start WinDV record, but I have never had a problem with it skipping frames or being rejected on any machine - very simple, small kb freeware program and saves me a huge amount of wasted time compared to other programs that import video but drop frames - can't recommend highly enough.
In case it affects you I'm using a legacy version of Vegas editing software - I got it to work on my Win 7 64 bit machine but had to installed the Dotnet 1.1 framework from Microsoft first which is a bit of a palava.
