slimbob
Hi
Any help is much appreciated on this !!
I have a old Panasonic NV-GS400 mini DV camcorder probably 10+ years old which I was using with my old P.C running XP (32 bit) windows and windows movie maker 2.1 software .... my camcorder was connected to my computer via firewire.
Every time I connected my camcorder to my computer it would recognise it.
My new P.C from P.C Specialist is running windows 7 (64 bit) Home Premium and I had a firewire card fitted by P.C Specialist with 3 firewire ports on it. I have windows movie maker 2.1 installed on my new Windows 7 P.C and also WinDV capturing software too.
However when I connect my Panasonic camcorder to my new P.C via firewire cable into firewire port my computer is not recognising any device at all ???
Normally I get a window pop up saying capture with windows movie maker.
Plus if I go into windows movie maker direct and attempt to capture video from external device ..... it shows an error message saying no external device could be found ???
Please help as I can't afford to buy a new camcorder!!!!! Plus my old one is more than adequate.
Any ideas ??
Thanks so much in advance if you can lend me a hand.
Best wishes
Bob
Any ideas ??
Best wishes
Bob
