AdamShorter800
Says in case description it comes with 3 fans (assuming these are the front 3 in the picture), can't see a rear fan in the case picture either.It comes with one on the rear but it’s just a basic PCS fan, no RGB I believe
PCS throw one in, believe @TonyCarter got this one, he can show you picsSays in case description it comes with 3 fans (assuming these are the front 3 in the picture), can't see a rear fan in the case picture either.
Sorry, I've got a 6500X, but I specified all Corsair QX iCUE Lin fans, so didn't get to see what would have been installed (plus mine didn't come with any from Corsair as it was a send-in-your-own).PCS throw one in, believe @TonyCarter got this one, he can show you pics
Apologies, I know someone got it, can’t remember whoSorry, I've got a 6500X, but I specified all Corsair QX iCUE Lin fans, so didn't get to see what would have been installed.
Thanks mate, I'll have to reach out to pcs to confirm the extra fan and either change it to rgb or add it. Do I need 3 fans on the bottom aswell or is that overkill?My 5000x came with a black PCS fan but that was over a year ago and I can't remember offhand if it was listed as included or not. My previous system with PCS also came with a PCS rear fan and it didn't mention having one included when I ordered it. So it's a 50-50 as to whether they include one or not.
My personal opinion is that it would look better with an RGB fan in place than the basic one (you can see the PCS one in the picture I posted earlier in the thread)
There are no bottom fan slots on the 5000X, although there are 3 more on the side...as shown in the below...but you don't NEED them.Thanks mate, I'll have to reach out to pcs to confirm the extra fan and either change it to rgb or add it. Do I need 3 fans on the bottom aswell or is that overkill?
I thought there was a shroud/airguide fitted if you don't have the side fans?You're just left with a gaping space without them. Aesthetically you definitely 'need' them.
I think there is, but the gap between the motherboard and front fans always looks so big that it feels like the space needs to be filled.I thought there was a shroud/airguide fitted if you don't have the side fans?
Personally I think there should be some RGB fans on the PSU and there seems to be a gap for another RGB fan in front of the PSU shroud - and maybe fit some fans externally in a push/pull configuration.
