Help first pc buy and need help been playing game consoles for 20 years ready for pc now
Take a read of this especially the bit on AMD v intel, also any specific reason you've gone for a custom loop
I’ll have a read now and I don’t even know what you mean by custom loop. I want the pc to be able to game at a high level really
custom loop is the liquid cooling system you've chosen
What's the budget, what monitor have you got, resolution & refresh rate or make and model
The other reason is because I live in a caravan which I’m the winter is nice a cool but in the summer it can get a bit warm
As said, it doesnt offer any improvement over an AIO. It's not meant for gaming rigs, only for high end render stations s or scientific data processors
£3k is the sort of price can go over a little
Well this should do nicely and comes in at £2510
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP
NOT REQUIRED
NO RECOVERY MEDIA REQUIRED
Firefox™
Standard Build - Approximately 16 to 19 working days
Price: £2,510.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/qDFd!gcYgd/
Do you already have the MSI monitor as if not, we could probably fit a far better one to match the build?
I’ve already got to monitor as used it on my Xbox. But open to opinions I am a competitive call of duty player so would like it to work really high FPS etc just want a good setup
Do you actually play competitively as in for a Team?
Have you experienced high refresh? If you've been on console all this time, the max refresh you've ever experienced will be 60Hz, but often even 30Hz. 144Hz is a significant difference to console, over that there's very little gain even for the professionals. There's a reason why pros are paid multiple million dollars per match, like any competition level, they actually are superhuman and have reactions and eyes far more sensitive than any of us.
Most humans can't appreciate any difference over about 120Hz, you hear a lot of nonsense on YouTube which is by "influencers" being promoted by paid ad spots. They have no idea of tech and don't understand that what they're saying is complete garbage.
The difference between 1080p 144Hz and 1080p 240Hz is marginal for a few, and non existant for most.
The difference between 1080p 240Hz and 1440p 144hz is huge, with 1440p being a far more enjoyable experience visually. 1080p is not really supported anymore outside of extreme budget systems and competition level where graphics aren't important.
I find competitively im better at 1440p then I was at 1080p as targets are more clear at distance and easier to spot
