BestUsername
I don't understand. The SSD has the OS on it. The HDD is my secondary drive.
I had same situation.Delete partition and do that again.Make sure to set both partitions as logical.Use the program what i give you in my previous post.
You need to assign a drive letter to the partition like I described before it will appear in "computer".I did what you said, setting it as logical. I then put it back to primary. I tried changing the path name etc.
Despite these three things I still cannot see it in my computer
I would try a clean install,delete all partitions when doing so or phone tech support.Yup, I did that too.
