Graphics Issue?
Unweakened
Right playing games is nice on the new rig, the only problem i've found is panning the camera from looking down to looking up in a slow motion makes the screen very jittery as if you shake the mouse when you look round in a game and also it makes a line of the game repeat for milliseconds but still long enough to notice and as much as it doesn't make a difference to gameplay it's annoying and shouldn't be like this from a brand new pc.
going left to right as if turning your head is fine it's just up and down. i'm assuming it's either the graphics card thats not rendering the game properly or is it something else? it happens on all games aswell so it's not one game with the problem.
Unweakened
Nope turnt on the vertical refresh rate and it made it worse
turnt it off and it was exactly the same as when i turnt it on.
Unweakened
Processor (CPU) AMD PHENOM II X4 970 (3.50GHz/8MB CACHE/AM3) - BLACK EDITION
Motherboard ASUS® M4A87TD/USB3: DUAL DDR3,SATA 6.0GB/s, USB 3.0
Memory (RAM) 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz (4 x 2GB KIT)
Graphics Card 2GB AMD RADEON™ HD6970 - 2 DVI,HDMI,2 mDP - DirectX® 11, Eyefinity 4 Capable
2nd Graphics Card NONE
Memory - 1st Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
2nd Hard Disk 1TB WD CAVIAR BLACK WD1002FAEX, SATA 6 Gb/s, 64MB CACHE (7200rpm)
RAID NONE
1st DVD/BLU-RAY Drive 4x BLU-RAY ROM DRIVE, 16x DVD ROM (£35)
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply 800W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan (£79)
Processor Cooling SUPER QUIET 22dBA TRIPLE COPPER HEATPIPE CPU COOLER (£19)
Sound Card Sound Blaster® X-Fi™ Xtreme Audio (£31)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire & Video Editing NONE
TV Card NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence
and games: Rift, WoW, Aoc, COD
Gorman
we have had a few reports of this sort of thing with the ATI / AMD drivers, i would recommend removing them completely and downloading the very latest from ATI. If that doesnt work it may be we need to revert to an older driver. What version are you running at the moment and is it the one we put on?
Unweakened
Version 2011.0104.2155.39304 and yes it is the one you guys put on i only got the pc thursday lol and i've had to ring up quite a few times since i have had it because even though it was tested. the pc was not even set up properly for first use.
Gorman
From what i have read the optical drive had a loose connection. This happens when we transport machines. The only way to guarantee that doesnt happen is to glue them in place, a practice that is employed by some system builders and is just ridiculous.
Having bought a high end AMD GPU, graphics drivers updates and problems with the latest release of drivers is just part of ownership im afraid, once you find a driver that works well most people tend to stick to it until they have read about peoples experiences of latest releases. The same applies to Nvidia but they have a better track record, barring that one time they released a driver which turned the GPU's fan off and burned out a load of cards.
The version number i am after will be the Catalyst Control Centre version, the latest being 11.2
Unweakened
yeh my nvidia burnt out thats why i dont use them anymore.
It says it's 11.0
Uploaded with ImageShack.us
Unweakened
it's awaiting being approwed my post because i put a picture on it for you but it is a 2011.0 version so it's .2 behind the version your lookign for. so DL the new one over the top? or uninstall then download?
Gorman
yeah it will automod images etc until you get to 10 posts but i can see them anyway.
Yep that gives us a good place to start, lets remove all ATI software, Driver and CCC then put on 11.2 and see what happens.
Gorman
remove through control panel then restart, then goto device manager and select the GPU, uninstall there and tick remove driver files. Reboot again and install the new ones, reboot and test.
Unweakened
doesn't give me the option in control panel only to repair. will do the other bits and delete then reinstall the 11.2 from website. brb
