Good for a first PC?
ItsPhire
Triple monitor setup
If my graphics card does not have 3 HDMI Outputs what can I use to use 3 monitors and still use hdmi? Is it like an hdmi splitter or something?
Rakk
The Awesome
4GB NVIDIA GEFORCE GTX 970 - DVI, HDMI, mDP - 3D Vision Ready
You can use a DVI-HDMI convertor and a mDP-HDMI convertor, you don't really want a splitter.
Noting that the only noticable difference between a DVI connection and HDMI is that HDMI carries sound as well.
PS. I've merged your threads together - it helps if you stick to one thread cos then people can see what you're ordering and so help advise on your later questions.
ItsPhire
Problen
I'm annoyed at my self because I like the NZXT H440 and the S340. I an going for a red and black case and if I pick the s340 I can have a 250gb SSD instead of a 120gb however it's blue and I don't think that'd work. Not sure what to do. I know the s340 would be better storage wise but not sure because I love the h440.
GeorgeHillier
Either case gives enough cooling and the S340 lets you get a bigger SSD, so i'd choose the S340 to get the better specs, not the better looking case as with the H440
GeorgeHillier
How much space does Windows 10 take up?
Not 100% sure. To give you an idea my laptop has a 120GB SSD and I have around 50GB free with very little installed on there, only google chrome and a few main programs that aren't that big.
I would definitely go for a 250GB SSD
ItsPhire
If I could fit in a GTX 970 would you recommend that over 250gb?
NZXT S340 MID TOWER GAMING CASE (BLACK/BLUE)
Intel® Core™i5 Quad Core Processor i5-4460 (3.2GHz) 6MB Cache
ASUS® H81M-PLUS: Micro-ATX, LG1150, USB 3.0, SATA 6GBs
8GB HyperX FURY DUAL-DDR3 1600MHz (1 x 8GB)
Free Item
FREE RAINBOW SIX OR ASSASSINS CREED with select GTX 9 Series GPUs!
1st Hard Disk
120GB Samsung 850 EVO SSD, SATA 6Gb/s (upto 540MB/sR | 520MB/sW)
Corsair H55 Hydro Series High Performance CPU Cooler (£39)
WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD (£12)
Price: £755.00 including VAT and delivery.
Fantana
If gaming is a priority think getting the best possible GPU is more important than the hard drive space. 120GB should be fine for a while, plus you you have another 1TB.
