I am a bit unsure of why you post it in this section. If you are set to get it but you don't want any recommendations? the hydro cooler is not needed for the cpu you have chosen and you may want to get at least silver warranty for £5.I have done research and I found that this seems to be good. Don't recommend any specs or anything, I appreciate the effort but I'm going to probably get this.
When I clicked on the post to forum it automatically posted it here. I'm just asking for an opinion on it, i'm probably getting it but i'd like a second opinion.I am a bit unsure of why you post it in this section.
It's because I want it watercooled.the hydro cooler is not needed for the cpu you have chosen.
It is hard to give an opinion without knowing if you had set a budget, if you have reached a set budget it is OK, although I agree with Keynes about water cooling. I would have gone with a better main drive, the WD fast drive is superior, although my preference would be that as a second drive and a 240GB SSD for the OS and main programmes. In short, if you like it fine but it would not be my choice.
My budget is £760. I can't afford any more and it's for his Christmas. The average I pay for him is 400-500
For around £760 you should be able to afford a gtx 970. If it is for Christmas prices will vary (hopefully cheaper) and other components may be available.
I5With what CPU?
I was wondering if somebody could make a PC build for me that doesn't exceed £765.00 (I 100% cannot go any higher)
I'm going to be playing GTA 5 and Black Ops 2, maybe some other games. I hope to get my graphics on High or even Very High at a decent frame rate. And an NXZT H440 is essential.
I'd appreciate if someone can make a build.
ItsPhire I've merged your question into your other thread since you are asking the same thing - it is better to stick to one thread when you're talking about the same thing cos then people wont ask/suggest the same things more than once.
Change the SSD, the V300s have performance issues, any of the other Kingstons or Samsungs will be fine and not much more expensive.
Is the "120GB SAMSUNG 650 SSD, SATA 6Gb/s (upto 540MB/sR | 450MB/sW)" good? And what build do you recommend
Get the 850 if anything. I'd go with the first build anyway
