Good build?
Fear
Well i would at least have your first HDD as a smaller 750GB-1GB drive and use a caviar black as they are more of a performance drive, unless you are doing lots of HD video editing 8GB will be plenty, for your intended use i don't think you will benefit from OC'ing also if you did you void the warranty if you damage the CPU with a failed OC and with the water cooling you do run the potential risk of it leaking. Don't forget if you want to write to cd/dvd discs you need to select 1 of the other drives.
Omnirat
COOLERMASTER HAF 922 MID TOWER GAMING CASE --------> InWIN BLACK DRAGON RIDER GAMING CASE £0.00
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT) --------> 8GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 4GB KIT) £-51.00
3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE --------> 120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW) £101.00
4x BLU-RAY ROM DRIVE, 16x DVD ROM (£38) --------> 12x BLU-RAY RE-WRITER DRIVE, 16x DVD ±R/±RW (£79) £41.00
COOLIT ECO II C240 A.L.C (ADVANCED LIQUID COOLER) (£99) --------> TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39) £-60.00
24" Widescreen TFT 1920 x1080 5MS, DVI, 23.6" Panel (£119) -------->19" Widescreen TFT 1360 x 768 2MS, D-Sub, DVI, 18.5" Panel (£79) £-40.00
Amendments Charge
Better?
Fear
Eeek don't drop the monitor you are getting a top end system and a low res monitor.
Teaz
The 24inch iiyama i recommended is top notch quality monitor. it will come coupled with a dvi cable so no need to purchase an extra cable.
Omnirat
COOLERMASTER HAF 922 MID TOWER GAMING CASE >>>>>>>>> InWIN BLACK DRAGON RIDER GAMING CASE £0.00
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT) >>>>>>>>>>> 8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB) £-51.00
3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE >>>>>>>>>>>> 120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW) £101.00
4x BLU-RAY ROM DRIVE, 16x DVD ROM (£38) 10x LG BLU-RAY >>>>>>>>>>>>> RE-WRITER DRIVE, 16x DVD ±R/±RW (£65) £27.00
COOLIT ECO II C240 A.L.C (ADVANCED LIQUID COOLER) (£99) >>>>>>>>>>> TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39) £-60.00
24" Widescreen TFT 1920 x1080 5MS, DVI, 23.6" Panel (£119) >>>>>>>>>> IIYAMA E2473HDS 24" LED WIDESCREEN, 2 x HDMI/DVI-D HD 1920x1080 (£169)
Good?
Omnirat
Changed to this... hopefully it will be OK;
Case COOLERMASTER HAF 922 MID TOWER GAMING CASE
Processor (CPU) Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
Change to: Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
Motherboard ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
Change to: 8GB SAMSUNG DDR3 DUAL-DDR3 1333MHz (2 X 4GB)
Graphics Card 1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
Change to: 600GB VELOCIRAPTOR WD6000HLHX, SATA 6-Gb/s, 32MB CACHE (10,000rpm)
2nd Hard Disk 3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
RAID NONE
SSD CACHE DRIVE NONE
1st DVD/BLU-RAY Drive 4x BLU-RAY ROM DRIVE, 16x DVD ROM (£38)
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 750W PRO SERIES™ HX750-80 PLUS® SILVER MODULAR (£116)
Processor Cooling COOLIT ECO II C240 A.L.C (ADVANCED LIQUID COOLER) (£99)
Change to: TITAN FENRIR EVO EXTREME HEATPIPE CPU COOLER (£39)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire & Video Editing NONE
TV Card NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
Office Software FREE Microsoft® Office Starter 2010 (Limited functionality Word & Excel)
Anti-Virus BULLGUARD INTERNET SECURITY - FREE 90 DAY TRIAL
Monitor 24" Widescreen TFT 1920 x1080 5MS, DVI, 23.6" Panel (£119)
2nd Monitor NONE
DVI-D & HDMI Monitor Cables 2 x 2 METRE DVI-D CABLE (£9)
Change to: 1 x 2 METRE DVI-D CABLE (£5)
Eyefinity / GeForce 3D Vision NONE
Keyboard & Mouse LOGITECH® G110 GAMING KEYBOARD WITH BACKLIGHTING (£69)
Mouse NONE
Speakers NONE
Change to: LOGITECH Z506 5.1 SURROUND SOUND SPEAKERS - 75W RMS (£79)
Webcam NONE
Headsets (VOIP) NONE
Surge Protection NONE
Printer NONE
External Hard Drive NONE
Warranty 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Change to: 3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (£5)
Home Installation NONE
Data Recovery NONE
Delivery DELIVERY BY 10 A.M WITHIN UK MAINLAND (MON - FRI) (£19)
Build Time FAST TRACK 3 WORKING DAY DISPATCH (£59)
Miscellaneous FREE Batman Arkham City with any Nvidia® GeForce GTX560 or above!
Fear
Ok i think what you have now on the above post looks a lot more of a balanced spec you can stick with that or if you want you could change that velociraptor for a 750GB caviar black as they are about the same speed effectively and the CB is quite a lot cheaper, you said £1800 well working to that as a max budget i would look at this below but do you want to be able to add a second GPU down the line if so then you would be best getting a 1050W corsair PSU and possibly if you have the room a Haf-X case which would take you to £1893.
With the Ilyama monitor in the spec below you get the DVI cable included so no need for the extras.
COOLERMASTER HAF 932 FULL TOWER GAMING CASE
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
Free Item
Memory - 1[SUP]st[/SUP] Hard Disk
2[SUP]nd[/SUP] Hard Disk
1[SUP]st[/SUP] DVD/BLU-RAY Drive
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£45)
2[SUP]nd[/SUP] DVD/BLU-RAY Drive
CORSAIR 650W ENTHUSIAST SERIES™ TX650 V2-80 PLUS® BRONZE (£72)
Monitor
Speakers
Price: £1,777.00 including VAT and delivery.
Omnirat
Thanks for the help Fear, have changed a lot according to your posted setup, it is now processing and hopefully I will have it this week with some luck + the fast build/delivery.
I'll be sure to post pictures :D
+Rep
