Good build?
Omnirat
Case COOLERMASTER HAF 922 MID TOWER GAMING CASE
Processor (CPU) Intel® Core™i7-2600k Quad Core (3.40GHz, 8MB Cache) + HD Graphics
Motherboard ASUS® P8Z68-V LX: USB 3.0, SATA 6GBs, ATI®CrossFireX
Memory (RAM) 16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (4 x 4GB KIT)
Graphics Card 1.5GB NVIDIA GEFORCE GTX 580 - 2 DVI, HDMI, DP - 3D Vision Ready
2nd Graphics Card NONE
3rd Graphics Card NONE
Memory - 1st Hard Disk 3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
2nd Hard Disk 3TB WD CAVIAR GREEN WD30EZRX, SATA 6 Gb/s, 64MB CACHE
RAID NONE
SSD CACHE DRIVE NONE
1st DVD/BLU-RAY Drive 4x BLU-RAY ROM DRIVE, 16x DVD ROM (£38)
2nd DVD/BLU-RAY Drive NONE
Memory Card Reader NONE
Power Supply CORSAIR 750W PRO SERIES™ HX750-80 PLUS® SILVER MODULAR (£116)
Processor Cooling COOLIT ECO II C240 A.L.C (ADVANCED LIQUID COOLER) (£99)
Network Facilities ONBOARD 10/100/1000 GIGABIT LAN PORT - AS STANDARD ON ALL PCs
Modem NONE, I WILL BE USING BROADBAND
Floppy Disk Drive NONE
Firewire & Video Editing NONE
TV Card NONE
Operating System Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence (£79)
Office Software FREE Microsoft® Office Starter 2010 (Limited functionality Word & Excel)
Anti-Virus BULLGUARD INTERNET SECURITY - FREE 90 DAY TRIAL
Monitor 24" Widescreen TFT 1920 x1080 5MS, DVI, 23.6" Panel (£119)
2nd Monitor NONE
DVI-D & HDMI Monitor Cables 2 x 2 METRE DVI-D CABLE (£9)
Eyefinity / GeForce 3D Vision NONE
Keyboard & Mouse LOGITECH® G110 GAMING KEYBOARD WITH BACKLIGHTING (£69)
Mouse NONE
Speakers NONE
Webcam NONE
Headsets (VOIP) NONE
Surge Protection NONE
Printer NONE
External Hard Drive NONE
Warranty 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Home Installation NONE
Data Recovery NONE
Delivery DELIVERY BY 10 A.M WITHIN UK MAINLAND (MON - FRI) (£19)
Build Time FAST TRACK 3 WORKING DAY DISPATCH (£59)
Miscellaneous FREE Batman Arkham City with any Nvidia® GeForce GTX560 or above!
Fear
What is your budget and usage requirements for this PC ? and don't forget to the silver warranty for £5 which extends the 1 month collect and return to a full year.
Omnirat
I have no budget, that's the PC that is currently being made for me by PCS and I was wondering if there's anything I can add in the near future if not now :)
Fear
Well if it has not gone into the building stage you can still make changes without being charged for altering the specs and you still have not said what you are using the PC for ?
Fear
Well you have a bit of a strange setup for gaming as 16GB of ram is way overkill 4GB is enough and 8GB for future proofing if the budget allows is more than enough, you have selected to super large HDD's and they are also the slower energy efficient ones they are good for storage but you don't want them for the main drive also are you actually going to OC the system as that is not needed for gaming and if you are not OC'ing then you are wasteing money on the k series CPU and water cooling.
Teaz
If its for that then this will be more than enough for it although thats quite alot of storage but can be adjusted to your preference:
InWIN BLACK DRAGON RIDER GAMING CASE
Intel® Core™i7-2600 Quad Core (3.40GHz, 8MB Cache) + HD Graphics
ASUS® P8Z68-V: USB 3.0, SATA 6GBs, NVIDIA®SLI™, ATI®CrossFireX
Free Item
120GB INTEL® 510 SERIES SSD, SATA 6 Gb/s (upto 450MB/sR | 210MB/sW)
3rd Hard Disk
12x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW (£45)
Monitor
IIYAMA E2473HDS 24" LED WIDESCREEN, 2 x HDMI/DVI-D HD 1920x1080 (£169)
Total: 2049
Configure it here :)
This will be more than enough and a more balanced spec.
Since you dont really have a budget, this is the spec to go :)
Fear
Another thing are you going to need to write to cd/dvd if so you also need a different optical drive as the 1 selected will only read.
Omnirat
Well it's already been ordered, I will have to check it out once it arrived, I may OC it since it's water-cooled and all.
Omnirat
Yes it's being processed, I tried to ammend to change some stuff but it seems it's costing me, I guess it should be ok.. I hope :)
Teaz
oh, thought it was still in the pre production stage. if thats the case, you can always ask for part orders then add it in yourself. PCS will guide you through it if ever stuck.
Fear
You would have to pay the price difference between the components if that is what you meant but seen as it is not in building stage and only in processing then i would strongly advise changing it no point buying a new PC and not getting everything right for what you want/need.
Teaz
No, it will not have problems running, it will just be a tad slow having the caviar green drive as the main drive as they are usually recommended as storage drive as said by Fear. The rest of the specs are fine but a tad overkill so my spec i posted up was a re done to balance it out.
Omnirat
I have now change the spec, I am using a 120GB intel first drive and the 3TB as a second drive, changed the cooling system, changed the RAM to 8GB, is it ok now?
