Good build for 4k60 and Unreal Engine?
Lockstar
CORSAIR CRYSTAL SERIES 460X RGB GAMING CASE
Intel® Core™i7 Six Core Processor i7-8700k (3.7GHz) 12MB Cache
Gigabyte Z370 AORUS Gaming 7: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready
32GB Corsair VENGEANCE DDR4 3200MHz (4 x 8GB)
11GB NVIDIA GEFORCE GTX 1080 Ti - HDMI, 3x DP GeForce - GTX VR Ready!
1st Hard Disk
6TB SEAGATE BARRACUDA PRO 3.5", 7200 RPM 265MB CACHE
NOT REQUIRED
CORSAIR 1500W PRO SERIES™ TITANIUM AX1500i DIGITAL MODULAR PSU
Corsair H80i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
2 PORT (2 x TYPE A) USB 3.1 PCI-E CARD + STANDARD USB PORTS
DVD Recovery Media
Windows 10 (64-bit) DVD with paper sleeve
Microsoft® Office Home & Student 2016 (1 Digital License)
Firefox™
Monitor
AOC U2879VF 28" 4K Monitor - 3480 x 2160, 1MS, HDMI, DVI, DP
2nd Monitor
ASUS Cerberus Keyboard & Mouse Bundle
Headsets
ASUS ROG ORION Gaming Headset
Home Installation
Technician Assisted Installation & Set-Up
Promotional Item
Get Destiny 2 with select GTX 10 Series GPUs! ** Limited Codes Available **
Price £3,663.00 including VAT and delivery: My budget can probably go up to about £4000, maybe £4500 at a stretch
Any opinions are appreciated :D
Lockstar
jerpers
Master
A few points:
You might as well go for a pre overclocked build
The HDD you have selected is very expensive. It would be more prudent to get an m.2 drive for your system for the speed and a basic 7200 HDD.
The PSU is massively overkill. An 850w would have room to spare.
The Noctua cooler is as good as the H80i and cheaper. If heavily overclocking, you would be better with the H100i
4k60 with on 1080ti is doable but on some games the settings need turning down a touch to keep it smooth. A second does not scale all that well for the huge cost.
Lockstar
I mean, I like running games at max settings, but I’m not really that fussed. I’m happy to turn down some settings so I can run 4K60. Apparently MSAA really isn’t needed for 4K so that should save some performance. Thanks for your input!
A few tweaks gives you better performance and dual 1080Ti's for not a lot of extra money.... relatively...
Overclocked CPU
Overclocked Intel® Core™ i7-8700K Six Core (3.7GHz @ up to 4.8GHz)
ASUS® ROG STRIX Z370-E GAMING: ATX, LGA1151, USB 3.0, SATA 6GBs - RGB Ready
2nd Graphics Card
1st Hard Disk
6TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 128MB CACHE
M.2 SSD Drive
256GB SAMSUNG PM961 M.2, PCIe NVMe (up to 2800MB/R, 1100MB/W)
NOT REQUIRED
Corsair H100i V2 Hydro Cooler w/ PCS Liquid Series Ultra Quiet Fans
Monitor
2nd Monitor
Headsets
Home Installation
Price £3,917.00 including VAT and delivery
Unique URL to re-configure : https://www.pcspecialist.co.uk/saved-configurations/intel-z370-overclocked/V7xBtZtDQt/
I would question your monitor selection though. It might be best to look for 4k monitors that support G-Sync (Nvidia) rather than Freesync (AMD) as you won't get the benefit of the technology.
A pair of 28" Predators would be my choice. I don't know if PCS have them (XB281HK). This would keep you within your £4.5k budget but stretch you over £4k with the above spec. Removing one of the Ti's would see you well within.
Edit:
Here is a SLI scale chart, you can determine if the games you want to play will warrant the dual cards or whether one would be fine...
https://forums.anandtech.com/threads/gtx-1080-ti-sli-performance-in-25-games.2501595/
The above spec by The_Scotster looks good.
I'd drop one of the extra 2 cooling fans because with the 3 front RGB fans that come with the case and the H100i V2 sitting in the top 2 fan mounts, there's only 1 mounting point still available for the fans.
A whole £3 saved there.
If you don't need the wifi off the Z370E, stick with the Gigabyte Ultra gaming. It has a similar featureset (USB 3.1 Gen 2 type C, SLI support, two M.2 slots, etc) and an additional USB port at the back as well.
I'd definitely question the original choice of monitors.
Also:
Given that you won't be running 2 games on 2 monitors at once, you could probably get a single 4k gsync monitor like the Predator, and then a cheaper 4k monitor as your 0ff-screen.
A larger SSD than 256gb would also be ideal, if there's the budget.
I like the idea of 4k multi screen gaming :punk:
I always recommend the 512s but the value isn't there from PCS at the moment hence why I went with the 256GB PM. I looked around outside and the price difference to buy on your own is significant, normally PCs is at least competitive.
The 960 Evo would probably be my choice buying retail, the Pro is a bit better (Similar to the PM vs the SM) but the differences only come into play +16GB transfers which is generally few and far between.
Lockstar
Which monitor (from PCS) would you recommend? Because I feel that gsync is a necessity. The extra performance from not using V-sync is great. If you would be willing to provide a screenshot, that would be good. Thanks for all your replies!
I wouldn't recommend any. They seem to be holding old stock/models/options.
Should I just go for the one I selected
Don't buy this. It's not worthy of your build or budget.
Buy a different monitor from elsewhere, with a 4k monitor with Gsync or a 1440p 144hz/165hz monitor with gsync.
PCS do have a couple of 1440p 144hz options that could be viable.
e.g. AOC AGON AG271QG 27" (not to be confused with the AG271QX)
ASUS 27" ROG Swift PG278QR
But you'll have far more choice and possibly better prices shopping around. Not to mention the absence of 4k gsync monitors from the PCS selection.
Lockstar
Also, how do you use a DisplayPort hookup? Do you just use a DP monitor cable and connect it between the case and the monitor? This is because most of the time, DP can do 60hz
Lockstar
I just have a question about DisplayPort. To connect it, is all I need a DP cable and a monitor that supports it? That's because it can get 60hz on a monitor.
Lockstar
For DisplayPort, is all I need a DP cable and a monitor that supports it? I want to use a DP setup so the monitor can run 60hz (at least)
I'm not sure I follow the question, could you rephase? *cough*
You just use a displayport cable, exactly like an HDMI cable or any other cable.
For 4K 60hz or 1440p high refresh you will probably need to use displayport due to the higher bandwidth than HDMI 1.4
Lockstar
How about this for a 4k monitor? It looks really good to me, 1ms Response Time, 60hz refresh rate, G-sync, DisplayPort, all for £529. Not bad tbh for that price, has everything I would want.
https://www.overclockers.co.uk/acer...BbPgYiCuaRr0kC4HDItLtuv37JFL_O2IaAqPuEALw_wcB
There's a link to the website so you can take a look for yourself.
If I was to get two of those, it would add up to around £1060. The grand total would be just over £3700, which is perfectly ideal since I'm getting a better dual-monitor setup.
Lockstar
Also, sorry for repeating the DP messages, I thought it wasn't going through. I apologise for any hassle, I liked your joke by the way, that made me laugh :D
When I press Proceed, it asks me which drive I want to install the OS on. Should I install it on the SSD? Apparently that's recommended and then using the hard drive for everything else. Thanks for all your help by the way!
There's a link to the website so you can take a look for yourself :D
I have one, if you don't mind sacrificing in terms of size (I'd say 32" is really the min for 4k) and a TN panel, then it's a really good buy and certainly the cheapest with GSync you'll find. I would recommend personally.
Lockstar
Wanna know why it wasn't appearing?
BECAUSE THERE WAS A SECOND PAGE TO MY THREAD.
I didn't notice. In fact, I'm glad my status says "New Member" xD
