Gigabyte B450 System Won't Boot
Status
Not open for further replies.
BCW100
After trying a few more suggested fixes by PCS (reseating power cables), somewhat to my surprise, their last chance suggestion of clearing the CMOS (as suggested above, by shorting the clear CMOS jumper pins) seems to have cracked it. I have no idea why this worked, or indeed how the fault happened, I did nothing between shutting down on Sunday and trying to boot up on Monday, and I have made no changes to the BIOS.
Anyway, having cleared the BIOS settings back to factory defaults, I am not sure if there any changes I should make to optimise this model of PC?
Your RAM is under the default speed, so you don't even need to set a DOCP overclock.
Everything should be good to go.
Luca07
I got the same problem i tried evrything but dram light is still there.My friend gaved me a gtx 750 ti and when i start the pc the dram light is on.
steaky360
If you start your own thread, put your specs etc. in from your PCS order page and let us know whats going on we can help there.
guirguis
i have the same problem the dram led red light but i tried everything, one ram in all the slots, cmos reset, another Gpu and nothing changed the dram led on and no power in the usb slots
specifications
gigabyte b450 elite
ryzen 5 2600
2× 8G hyperx 3200 ddr4
radeon rx 590
specifications
gigabyte b450 elite
ryzen 5 2600
radeon rx 590
Again, if you start your own thread please
Status
