Thank you I jest sent a Q above it would be appreciated if you can helpNo problem at all!
If you're putting a build together we would be happy to give you some pointers/ potential optimisations. Just let us know!![]()
I just realised it’s a portIt's an ethernet port which is part of all motherboards.
I have ordered I’m just checking If I need a wifi thing but it looks like i need one which is fineHave you already received a system or are you looking to order?
Sorry if this is annoying can I use a wifi card with my mobo if so please can you recommend any good ones? (gpu= 3060)No, there's no wifi on that board.
I'm still unclear, have you received this PC or is it still in the queue? If it's still in the queue you can amend it without affecting your place. I would strongly advise getting some pointers on the full system if you're unsure of what motherboards are?Sorry if this is annoying can I use a wifi card with my mobo if so please can you recommend any good ones? (gpu= 3060)
Edit thank you
No it’s fine I just got a bit confused like I just confused my selfI'm still unclear, have you received this PC or is it still in the queue? If it's still in the queue you can amend it without affecting your place. I would strongly advise getting some pointers on the full system if you're unsure of what motherboards are?
Hey I got a gigabyte oneMost likely, Zotac, sometimes Palit. Gigabyte is too expensive to randomly give away.
You can adjust that in Armoury Crate.I got the
With a Corsair cv 650 (PSU) the motherboard has a few small RGBs on but when I turn it off they stay on is there a way to make them turn off when u turn my pc off?
