Gaming PC too loud ?
Status
Not open for further replies.
itsharry888
Hiya, i bought a gaming pc in June (specs below) and its extremely loud, even when just idle or browsing the internet etc - and unbearable really during gaming, even for less demanding games like cs:go. Does anyone know how to find out whats causing this? how do i know if its the case fans? gpu? cpu? etc. FYI my GPU gets to about 73 degrees in heaving gaming - the PC is well ventilated at the moment also. Thanks in advance for the help.
Item Weight 11 Kg
Manufacturer reference CAP22-GPCW7
Processor Brand AMD
Processor Type Athlon
Processor Speed 3.40 GHz
Processor Socket FM2
Processor Count 4
RAM Size 8 GB
Computer Memory Type DDR3 SDRAM
Hard Drive Size 1 TB
Hard Disk Technology SATA
Hard Drive Interface Serial ATA-600
Graphics Card Description Radeon R7 260X
Graphics RAM Type DDR3 SDRAM
Graphics Card Ram Size 2 GB
Graphics Card Interface PCI-E
Optical Drive Type DVD/CD
Hardware Platform PC
Operating System Windows 7 Home Premium 64-Bit
mantadog
Superhero Level Poster
Noise will be coming from the GPU/CPU fan or the PSU or perhaps the case fans.
You need to isolate each one and see if it makes the noise better/worse. YOu can start by running prime95 to stress the CPU, then using afterburner or catalyst control centre software to ramp the fans on the GPU to see if thats causing it. if not check the case fans.
tshayter
Take some time to listen closely to the machine. Perhaps if you can open the side too. That way you might be able to work out whether the sound is coming from the fans or a hard drive or something else.
When you know where most of the noise is coming from you stand a better chance of finding out if there is a way to fix or improve the issue :)
itsharry888
thanks for the help - ive tried opening the sides but that hasnt been much help - i used prime95 and it got alot louder, even when it was on only for a minute? idk if that means that its the cpu, i tried the amd catalyst to turn up the gpu fans and didnt really notice any difference.
Sounds like it's the CPU fan then perhaps. Which cooler do you have? If it's the stock one, then these run extremely loud. They're easy enough to swap out for a decent one, just need to repaste the cpu and seat the new heatsink.
GeorgeHillier
If it's the cpu fan then get a can of compressed air and spray the heatsink with it. My AMD heatsink got full of dust every 6 months or so, seems to be a dust magnet.
itsharry888
yeah its the stock one i havent changed it - when i bought it from amazon it was listed like £30 cheaper than the others that had exactly the same specs - so i guess they just cheaped out on the fans -_-
thanks for the help guys :)
itsharry888
thanks - anyone recommend any fans for my cpu (AMD Athlon 750k 3.4GHz quad core), my motherboard is FM2+ socket.
preferabely from amazon also.
itsharry888
Yeah will consider them both - thanks guys - was just also wondering whether the psu fans were meant to be fairly audible - theres a considerable humming coming from them aswell that i only really notice during idle use. Not sure if theres anything i can do to stop that though? its 600w if that helps:)
Status
