Gaming computer for
Tadhg21
Oke so at this point now im stumped. What would ye suggest I do?
I want a Gaming computer that will last for years to come and also be able to do my work related stuff on it like rivet/autocad and photoshop and not have it slow down like crazy when i do instensive work on it. I'd really like to keep the price at 2000 but obviously im willining to go a little bit more to ensure a good build.
steaky360
Err no idea, if there isn't an option for one in the configurator you wont have an issue getting the 'k' version. All the k shows essentially is that its multiplier unlocked for overclocking. You don't need to worry about that though, it doesn't make a difference if you don't overclock it.
Tadhg21
OKe so i should just go ahead and get that CPU then? Intel® Core™i7 Quad Core Processor i7-4820K (3.7GHz) 10MB Cache?
Tadhg21
Well what would be the difference between there 2, aside from the overclock thing :p
Intel® Core™i7 Quad Core Processor i7-4820K (3.7GHz) 10MB Cache vs Intel® Core™i7 Quad Core Processor i7-4770 (3.4GHz) 8MB Cache?
steaky360
Well they're different sockets, you'd need a different motherboard for either of them. the 4820k is a socket 2011 processor whereas the 4770 is a socket 1150.
The 4820k has a 10mb cache and a higher base clock speed (neither of which will make much of a difference for you I don't think) and can support more ram (4820k:64gb vs 4770:32gb) both are overkill though as 16gb is likely more than enough.
4820k: http://ark.intel.com/products/77781
4770: http://ark.intel.com/products/75122
Tadhg21
Thanks for the links, I was just doing some reading and now im thinking just get the i7-4770. If ye think it will suit all my needs and will last me for a long time I may be set in my decision :D
It says it can Turbo Boost to 3.9, What does that mean?
steaky360
The maximum clock speed the processor will reach (before any overclocking tweaks are done) is 3.9Ghz
Tadhg21
COOLERMASTER CM690 MKII ADVANCED CASE
ASUS® Z87M-PLUS: m-ATX, USB3.0, SATA 6.0, XFIRE
16GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz, X.M.P (2 x 8GB KIT)
3GB NVIDIA GEFORCE GTX 780 - 2 DVI, HDMI, DP - 3D Vision Ready
Free Item
Free Item
FREE ASSASSINS CREED BLACK FLAG with GTX 660 & 7 Series GPUs!
240GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 555MB/sR | 510MB/sW)
4x BLU-RAY ROM DRIVE, 16x DVD ROM
CORSAIR 650W CS SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET (€84)
Super Quiet 22dBA Triple Copper Heatpipe Intel CPU Cooler (€24)
Genuine Windows 8.1 64 Bit - inc DVD & Licence (€96)
Monitor
IIYAMA E2273HDS 22 (€145)
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) (€16)
2 - 3 DAY DELIVERY TO REPUBLIC OF IRELAND (€24)
Oke so this is the way its looking right now, Im just curious as well about the motherboard options. Is the one I've selected good?
The On board sound is only 5.1 why cant I change it to 7.1?
And once again thanks for the patience for answering all these seemingly to ye silly questions lol
EDIT: Yeah Keynes I saw that post but at that point I was dead set on the OC option, sorry :(
The motherboard you selected is a micro-ATX boards, it doesn't have as many expansion slots as the standard ATX. If you don't need those it is fine. As I mentioned in a previous post I don't think the collect and return will apply to you since you are located outside the UK. You may want to confirm that with PCS before adding silver warranty.
Tadhg21
Will that affect an SLI of another card down the line?
Yeh I will contact them monday and see about the silver warranty, thanks for the reminder :)
Tadhg21
Oke so change the motherboard to ASUS® Z87-A: ATX, USB3.0, SATA6GB/S, SLi, XFIRE?
And is it hard to change the PSU later on or would you advise doing it now?
Tadhg21
Ah well then SLI is out of the question then :( So how does this look then as the final build of it.
Free Item
Free Item
Monitor
Quantity 1
Tadhg21
Oke last newbie question and I promise i'll leave ye wonderful people alone heh
Do I need to get cables in the order or will they come with it? i.e for the monitor etc and what kind of cables would be best for gaming?
