I tried to add onto build but was coming up with an error msg.
"The case you have selected includes 2 RGB LED strips as standard.
Please remove the LED strips from your selection.
Unfortunately the case you have selected does not support LED lighting. Please select a different case or alternatively remove the LED lighting from your configuration."
So I assume not able to add the RGB LED strips ? Or should I mention it when I speak with PCS about the other component (CPU Cooler)
Yeah, you are not able to add them because they are already included. https://www.youtube.com/watch?v=B1fE8vJGly8#t=3m . To be 100% sure ask PCS .
