DarkPaladin
Sometimes, if a game is old enough, downloading the NVIDIA PhysX Legacy Drivers can help (2007 releases or earlier). I checked the release dates of the games you've mentioned and while they don't meet the 2007 threshold, they are pretty close. It might be worth looking into it (I would only resort to this after attempting the other potential fixes first): https://www.nvidia.com/en-gb/drivers/physx/physx-9-13-0604-legacy-driver/
Additionally, while I'm aware you've tried capping the FPS, you could try altering the refresh rate in the NVIDIA Control Panel. I had to cap my 144HZ laptop resolution to 60HZ in order to make Sonic Adventure 2 run correctly:
- Nvidia Control Panel
- Change Resolution
- Refresh Rate
- 60HZ
- Go to Nvidia Control Panel --> Manage 3D Settings:
- Under the global settings tab. Set the DSR Factors to off.
- Now Go to the Program settings tab and select legobatman.exe and set the Max Frame Rate to 60FPS.
