Hello everyone,
I'm looking to make an AMD build for the first time and I've done lots of research but could use some advice before moving forward with purchase. The primary use will be gaming which doesn't include streaming.
I've copied my specs below. Any feedback is appreciated but I will add my main query/concern is whether or not the B550 motherboard is worth purchasing over an X570 board.
Note: I have SSD/HD storage ready.
Thanks in advance!
Budget £1,500-£1800 (being marginally over the budget isn't a big deal)
https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/Ar8QB6Tdxf/
8GB ASUS ROG STRIX GEFORCE RTX 2070 SUPER - 2 x HDMI, 2 x DP
128GB ADATA SX6000 LITE M.2 2280 (1800 MB/R, 1200 MB/W)
STANDARD AMD CPU COOLER
Monitor
IIYAMA G-MASTER GB2760QSU-B1 27"
Thanks in advance!
Monitor
