final spec check. ordering soon :D
JSG10
Expert
I decided to be patient, was done a little quicker than I expected but after the first day or two I was really tempted to phone up and upgrade to 5 day delivery lol
Phoenix
Just thought I'd add that 1920x1080 doesn't give you a better quality picture than 1680x1050 it just gives you more screen space to look at/work with.
Slurpak
thanks pheonix, i didn't realise that.
the spec that i have at the moment stands at this:
COOLERMASTER CM690 MKII ADVANCED CASE
Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55D-E PRO: USB 3.0, SATA 6.0GB/s, CrossFireX™ / SLI SUPPORT
1280MB NVIDIA GEFORCE GTX470 GDDR5 PCI EXPRESS - DirectX® 11 + MAFIA II
Free Item
FREE MAFIA II Game (RRP: £34.99) with a qualifying GTX 4xx Series GPU!
Power Supply & Case Cooling
CORSAIR 850W PSU (TX850) 80+ ULTRA QUIET (£99)
INTEL SOCKET LGA1156 STANDARD CPU COOLER
WIRELESS 802.11N 300Mbps PCI CARD (£16)
GeForce 3D Vision
GeForce 3D Vision Kit & ViewSonic FuHzion 22" VX2268wm 120Hz LCD bundle (£319)
Logitech® G15 Gaming Keyboard with Gamepanel LCD Display (£69)
Mouse
Logitech® G500 Laser Gaming Mouse (£39)***SPECIAL***
Standard Build - Approximately 9 to 13 working days
Price: £1,305.00 including VAT and delivery.
gone slightly over budget there thanks to the 3D, but im sure it'll be worth it. can't wait to do some 3d gaming. and assuming that all the parts are in stock when i order it (which they arn't at the moment) im going to go with the fast track delivery aswell. hopefully be ordering in the next week or two, so i still have plenty of time to make any more adjustments if i need to.
i just have 2 questions:
1) is that spec ok for adding a second GTX470 in the future? (is the PSU enough, and will the case fit it?)
2) is that spec ok for the 3d vision technology? the GTX470 will let me use 3d won't it?
Phoenix
Looks good, yeah the power supply is big enough for a second GTX470 and the case is large enough. The GTX470 will be fine for 3D but the other (MAJOR) advantage of getting a 3d-capable monitor over a normal one is that you have a refresh rate of 120hz so even if you don't bother using it for 3D you won't have to use V-sync to prevent screen tearing up to 120FPS. Ghosting also goes away with 120hz monitors which is pretty cool.
