Fan is not spinning
Hello,
I have noticed that my Vyper 17.3 CPU fan is not spinning no air is coming out, even when im playing or working. GPU fan seems to be fine, the air is blowing out from the right side and back of the laptop, but nothing comes out from the left side+back.
CPU goes as high as 80-90c even when using a low resource programs/games.
I received this laptop few days ago, and noticed this problem straight away, also i have sent a few emails asking for help from techsupport but still no answer from them.
Is there anything i could do or try to do to fix this by myself? if it's possible of course..
Thank you
Below is my laptop spec:
Chassis & DisplayVyper Series: 17.3" Matte Full HD 144Hz 72% NTSC LED Widescreen (1920x1080)
Processor (CPU)Intel® Core™ i7 Eight Core Processor 10875H (2.3GHz, 5.1GHz Turbo)
Memory (RAM)32GB Corsair 2666MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® RTX 2070 - 8.0GB GDDR6 Video RAM - DirectX® 12.1
1st M.2 SSD Drive1TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
Memory Card ReaderIntegrated Micro-SD Memory Card Reader
AC Adaptor1 x 230W AC Adaptor
Power Cable2 x 1 Metre UK Power Cable (Kettle Lead)
BatteryVyper Series Integrated 91WH Lithium Ion Battery
Sound Card2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & WirelessGIGABIT LAN & WIRELESS INTEL® Wi-Fi 6 AX201 (2.4 Gbps) + BT 5.0
USB/Thunderbolt Options1 x THUNDERBOLT 3 PORT + 3 x USB 3.1 PORTS
Keyboard LanguageVYPER 17 SERIES RGB BACKLIT UK KEYBOARD
BrowserFirefox™
Have you got Gaming Center U installed? It's a control program, should be in running programs in the taskbar?
It may be worth opening up the bottom of the laptop and just checking the CPU fan cable is plugged in. You're allowed to open it up without affecting warranty, PCS have an open chassis policy so you can perform any upgrades or amendments or maintenance you like so long as you don't do any damage in the process.
Hi, this is what i see.
1 more question
Both fans seems to be working, however, the marked area still gets very hot, i dont know if this is normal.
Thanks for the help.
With FAN boost mode on, fans are working really loud but at least they keep CPU and GPU with lower/low C*, but the middle of the laptop where is the pipes still gets really hot, probably it's normal, dunno..
The best way to be sure is monitor your temps with HWMonitor when idle and under load, that will tell you if there's any out of bounds overheating:
