Before I purchase the new build I've been reading reviews on the processor (i7 6850k) and it seems others are recommending to only get the 6800k if you intend on only 1 gpu as you don't require the 40 pci lanes of the higher model is this the case?
28 on the 6800 and 40 on the 6850 I imagine 28 is enough for 1 gpu plus everything else in the system. Would there be any benefit of the higher model at any point or going forward?
I thought I'd ask as this is getting down to a technical level I don't normally explore. But might aswell buy it right first time 😄
