Defiance Series: 17.3" Temps
Update after playing I am bread for 15 mins. Still not best pleased and am waiting to hear from PCS on Monday when they're open.
de4life
Whilst the average temps are nothing to be worried about, I assume the laptop is maintaining them through thermal throttling which is going to impact your clock speed. I wouldn't consider that an acceptable performance considering the cost of the laptop.
Exactly as I thought! We will see what the support team says tomorrow. As before I’ll keep this thread updated
Time was I'd have agreed, however, a degree of throttling due to power and/or thermal limits is extremely common on 8th and 9th Gen laptop CPUs. This is probably not too surprising when Intel have been using CPUs like the 6700HQ on a 45W TDP, then bumped frequencies and added 50% cores on basically the same architecture. With the same TDP.
See: https://www.pcspecialist.co.uk/forums/threads/reported-throttling-on-8th-gen-mobile-chips.60205/
And see: https://www.kitguru.net/lifestyle/m...-recoil-ii-i7-8750h-gtx-1060-laptop-review/3/
Starting with the CPU, a peak of just 81C is a top result, and that is only furthered by the fact that this temperature came with the CPU clock speed holding at 3.1GHz across all cores. The [MSI] GS65, for instance, could only push all 6 cores to 2.8GHz, and even then the CPU still peaked at 85C.
Of course it's a question of degrees (no pun..). If it's throttling down to base frequencies under gaming load and/or melting itself in the high 90s (as yours seem to be), I wouldn't consider that acceptable either. But say you repaste and see temps in, say, the high 80s during intensive gaming and frequencies only a little over 3GHz, that's not entirely uncommon.
