Hi guys,
Bought a new pc and it was delivered last week, with a bit of...transit "damage" to it (card reader - only half showing in the bay, GPU had to be resitted and top of case was slightly damaged) All 3 are fixed now but I'm somewhat worried about the temps of my CPU. My mobo is Asus Rampage IV extreme.
I have a stock i7 3820 and a Spire Gemini rev.3 cooler 600-1800 RPM IIRC.
When the fan is running at 600 (well, it was actually running at 580) my cpu temp was 45c I have just made the fans go at max (1700 RPM according to bios) which dropped the temp a few degrees.
Now with using Core Temp 1.0, I recorded the idle temps and full load temp using intel burntest.
Idle
Core #0 35c
Core #1 34c
Core #2 36c
Core #3 38c
Full Load
Core #0 74c
Core #1 70c
Core #2 78c
Core #3 82c
Could the fan need resitting due to transit? My room temp is about 18c mobo 28c case is about 22-25c GPU (GTX 680 4GB) is 30c idle @ 30% fan speed.
Cheers!
Idle
Core #0 35c
Core #1 34c
Core #2 36c
Core #3 38c
Full Load
Core #0 74c
Core #1 70c
Core #2 78c
Core #3 82c
Cheers!
