meinthecorner
Hi - Looking for some pointers.
I have the following machine built by PCS and it has been running 24/7 since November 2023
AMD Ryzen 9 7950X 16 Core CPU (4.5GHz-5.7GHz/80MB CACHE/AM5)
PCS FrostFlow 240 Series RGB High Performance Liquid Cooler (AMD)
The issue, today it just shutdown and when I try and boot, it just shuts down loading windows. If I turn it on straight away the BIOS warns the CPU is to hot.
If I wait 5 mins and power it on and get into the BIOS the temperature reported is 84c with the following fan speeds reported
W_pump+ = 1253
AIO pump = 2180
As I'm in the BIOS the temp creeps up and the machine powers down again.
I've tried to lookup if these pump speeds are normal but cant find spec data. I've checked the block and there is no dust buildup etc.
I've checked the qfan control area in the BIOS and the settings are on MAX.
Any other troubleshooting suggestions? The machine isn't used for Gaming, just a Plex Server, CCTV Server and video file rendering. It's been flawless for well over a year!
Cheers
W_pump+ = 1253
AIO pump = 2180
Cheers
