Hi
First time I've had a problem in months and now it wont load windows.
so this is what happened -
When putting the computer into sleep mode it seemed to have crashed and everything went black and it wouldnt turn off by pressing power button so after a little while I had to turn it off at plug.
next day when booting it up it said it didnt shut down properly and then loaded me back to my desktop without having to enter my password or anything, it seemed to be working fine although I noticed that the OC setting were not there when I checked the system properties so when I shut it down and restarted it a bit later the first thing I noticed was that the fan was running fast and was quite loud and then it wont go any further than the screen that says windows detected a problem select to repair or load windows.
If I pick repair it says it cant fix it and if i want to run memory diagnostic tool which I did and it says drives are ok, then I picked system restore - but said it couldnt complete successfully and details were - an unspecified error occurred during system restore (0x800700b7) then it restarted.
But if I pick load to windows it gets to the loading windows screen and then crashes to this blue screen -
I also tried putting the windows cd in and running repair from there but just get the same results as above.
Anyone got ideas?
Specs are -
COOLERMASTER HAF 922 MID TOWER GAMING CASE
OverClocked Intel® Core™i7 Quad Core Processor i7-930 (2.8GHz @ max 3.8GHz)
ASUS® P6X58D-E: DDR3, USB 3.0, SATA 6.0GB/s, 3-Way SLI
6GB CORSAIR XMS3 TRI-DDR3 1600MHz (3 X 2GB)
1GB ATI RADEON™ HD 5870 PCI EXPRESS - DirectX® 11
50GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
100GB OCZ VERTEX 2 SATA II 2.5" SSD (upto 285MB/sR | 275MB/sW)
10x BLU-RAY ROM DRIVE, 16x DVD ±R/±RW
CORSAIR 850W PSU (TX850) 80+ ULTRA QUIET
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER
ARCTIC COOLING MX-3 HIGH THERMAL CONDUCTIVITY COMPOUND
Sound Blaster® X-Fi™ Titanium - Fatal1ty Professional Series
ONBOARD 10/100/1000 GIGABIT LAN PORT
Genuine Windows 7 Home Premium 64 Bit - inc DVD & Licence
Microsoft® Office Starter 2010 (Limited-function versions of Word & Excel)
MICROSOFT SECURITY ESSENTIALS - Free Basic Protection
LG W2753VC-PF 27" WIDESCREEN, HDMI/DVI-D FULL HD 1920x1080
LOGITECH X-540 5.1 Surround sound effect with full range and deep bass
Ta
JJ
Anyone got ideas?
Specs are -
Ta
JJ
