Case | CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE |
Processor (CPU) | AMD Ryzen 9 3900X 12 Core CPU (3.8GHz-4.6GHz/70MB CACHE/AM4) |
Motherboard | ASUS® ROG STRIX X570-F GAMING (USB 3.2 Gen 2, PCIe 4.0) - ARGB Ready! |
Memory (RAM) | 32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 8GB) |
Graphics Card | 10GB NVIDIA GEFORCE RTX 3080 |
1st Storage Drive | NOT REQUIRED |
1st M.2 SSD Drive | 1TB SEAGATE FIRECUDA 520 GEN 4 PCIe NVMe (up to 5000MB/R, 4400MB/W) |
2nd M.2 SSD Drive | 1TB PCS PCIe M.2 SSD (2000 MB/R, 1100 MB/W) |
DVD/BLU-RAY Drive | NOT REQUIRED |
Power Supply | CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET |
Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
Processor Cooling | Corsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler |
Thermal Paste | STANDARD THERMAL PASTE FOR SUFFICIENT COOLING |
LED Lighting | 2x 50cm RGB LED Strip |
Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
Wireless Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS |
Operating System | Windows 10 Home 64 Bit - inc. Single Licence [KUK-00001] |
Operating System Language | United Kingdom - English Language |
Windows Recovery Media | Windows 10 Multi-Language Recovery Image - Unlimited Downloads from Online Account |
you should have access to onedrive as its part of your microsoft accountWhat is the best free cloud to upload to as i don't use them?
Can you please let me know if that works. thanks.you should have access to onedrive as its part of your microsoft account
Does that work? I have never uploaded from cloud before lolNo, you need to upload the files, then create a link to them, check out this article:
4 ways to share files and folders from OneDrive | Digital Citizen
How to share files and folders stored in OneDrive, from a Windows 10 PC, an Android device, an iPhone or iPad, or a web browser.www.digitalcitizen.life
Still having same issue.You need to install those updates mate including all the optional updates, your Windows is currently pretty out of date
Yeah might be an idea, use the following methodI was thinking maybe doing fresh install of Windows
