JackKnowsNothing
Hi all,
I ordered a custom PC about 5 years ago and now that windows 10 is going to expire next year I'm using this as an excuse to get a new nicely spec'd PC.
I've listed the spec below but before that I want to raise a few questions in general as well as what I'm looking for.
1. I have very little knowledge of how to maintain hardware/software, and as I'm looking for this next spec to last 5+ years should I just buy off the shelf? I've looked, but the machines seem to be almost twice as expensive for the spec you can build custom on a site like this.
2. Even if I do buy off the shelf I'm assuming it will need maintenance to a certain degree anyway?
What I'm looking for/things to consider:
- Power efficient (may be on all day and I don't want sky-high energy bills/wasting electricity) - although this may be a software based question?
- Very quiet
- Output to 2 monitors
- Good Bluetooth (for mouse and keyboard)
- WIFI (built in with strong range)
- To be well cooled (can handle heavy workloads throughout a hot summers day)
- I'm pretty square so I don't need it lit up like a Christmas tree
Monitor - 2 x ASUS VA229HR - Resolution - FHD 1080p, Refresh rate - 75Hz
Uses - Primarily need a workhorse for online/browser windows - lots of difference tabs. Secondary - gaming (just need it to be capable, not looking for high end)
Max Budget - 1.2k
Note: the below build was based on https://www.pcspecialist.co.uk/view/Blaze-Elite/ I just upgraded a few parts:
FRACTAL POP SILENT CASE TG (BLACK)
GIGABYTE B550 GAMING X V2 (AM4, DDR4, PCIe 4.0)
8GB NVIDIA GEFORCE RTX 3050 - HDMI, DP, LHR
Graphics Card Support Bracket
CORSAIR 650W CX SERIES™ CX-650 POWER SUPPLY
PCS FrostFlow 200 Series High Performance CPU Cooler
WIRELESS INTEL® Wi-Fi 6E AX210 2,400Mbps/5GHz, 300Mbps/2.4GHz PCI-E CARD + BT 5.0
Microsoft® Edge
Price: £1,214.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/e0vJDNHhJu/
My monitors:
2 x ASUS VA229HR 21.5 Inch Monitor, FHD (1920 x 1080), IPS, 75 Hz, VGA, HDMI, Low Blue Light, Flicker Free, TUV Certified
- Very quiet
Max Budget - 1.2k
Microsoft® Edge
My monitors:
