Anthony.Ralph
My new PCSpecialist computer works well when connected to the monitor with the supplied displayport lead. As I only have standard USB-C sockets on the pc, I cannot just use a USB-C cable to the monitor to use the memory card slot, the two USB 3 sockets in the monitor as well as send the video signal to the display. Obviously a USB-C cable can be used in tandem with a displayport to provide all connectivity.
My questions are...
Would it be best to fit an add-in card to provide video as well as supporting the other elements mentioned above through the USB- cable and what spec/supplier would be the recommendation?
In the PCSpecialist component list when creating a pc spec, mention is made of a card with a Thunderbolt connection, is this what I need and do PCSpecialist supply add on components?
And finally, if it is best (and economic) to continue with the displayport connection setup, what would be the recommendation for a decent quality cable supplier as I need a longer cable length (2.5 - 3m)
As always, all information gratefully received. Anthony
My questions are...
