Citrus_9
Expert
You may end up homeless š³I daren't tell anyone in my family I've ordered a new PC until the day it turns up at my door...not sure if that's a good idea or a bad idea![]()
Well worth it though, so long as you can tap into the nearest street lamp for electricity and get a mobile 4g router, you're sweetYou may end up homeless š³
Just set up an induction coil on the local substation, and why do you need a 4g mobile router with all those green boxes by the side of the road................Well worth it though, so long as you can tap into the nearest street lamp for electricity and get a mobile 4g router, you're sweet
Edit: Please don't anyone take that seriously!
Sounds perfect! Wouldn't even need a heater to keep warm, PC would do that for meWell worth it though, so long as you can tap into the nearest street lamp for electricity and get a mobile 4g router, you're sweet
If Iām right, thatās the older model and it was known to have various issues. For the sake of an extra Ā£200 on top of your current spend, I wouldnāt compromise on the monitor.Just been looking at alternatives to the Odyssey G9 and I've seen this below. It's not quite 240Hz but how would this be for a 3080Ti (or 3090 if it ends up being built a lot sooner than planned)?
Link is mahoosive!!! So click here
I'm definitely thinking of going from 2 screens to 1, so would want something that I could carry out multiple windows of tasks on
Budget's not a problem, it's okay! I'll give it a few months before going for the G9 then, might get my current monitors on the FB marketplace once it's been delivered. Never had a widescreen so it's gonna be strange to get used to!If Iām right, thatās the older model and it was known to have various issues. For the sake of an extra Ā£200 on top of your current spend, I wouldnāt compromise on the monitor.
From the looks of things, Iāve assumed so far that budget isnāt a problem. But if finances are getting stretched, you can tweak your storage options to make the G9 achievable š
Samsung are releasing an upgraded model of the G9 in July and the current one will no doubt come down in price a bit.Budget's not a problem, it's okay! I'll give it a few months before going for the G9 then, might get my current monitors on the FB marketplace once it's been delivered. Never had a widescreen so it's gonna be strange to get used to!
I really hope my desk is long enough...
Dont tell everyone !!!!!! im going to try and nab oneSamsung are releasing an upgraded model of the G9 in July and the current one will no doubt come down in price a bit.
