Benchmark Results Leaderboard
Just for fun, post your 3DMark scores here. Please also include the online results page so we can see your spec and drool. or laugh.
For 3DMark, download here:
http://www.futuremark.com/benchmarks/3dmark
Please run the Firestrike test and post the results page link. It has GPU, CPU and combined score so it should give everyone a better idea of performance.
Here are the PC leaderboards:
3DMark
1. halox 18621 http://www.3dmark.com/3dm11/7422914
2. Steaky360 15304 http://www.3dmark.com/fs/479171
3. Gazza 13669 http://www.3dmark.com/fs/917333
4. Bsrz 13018 http://www.3dmark.com/fs/774897
5. Numpty 12752 http://www.3dmark.com/3dm/1120610
6. Rustilol 12646 http://www.3dmark.com/fs/2222445
7. Jaystar 11249 http://www.3dmark.com/fs/1767452
8. halox 11067 http://www.3dmark.com/3dm/1249675
9. Tom DWC 10996 http://www.3dmark.com/fs/489705
10. TheGeeza 10803 http://www.3dmark.com/3dm/2501680
Here are the LAPTOP leaderboards:
3DMark
1. Stormbrook Omega II 8390 http://www.3dmark.com/3dm/1695436
2. Punchuk 5202 Vortex III http://www.3dmark.com/3dm/2589818
3. zulubear 5186 Vortex IV http://www.3dmark.com/fs/659694
4. malgall 5139 Vortex IV http://www.3dmark.com/fs/1193625
5. driedeker 5134 Vortex IV http://www.3dmark.com/3dm/1714610
6. M3zxu 5091 http://www.3dmark.com/3dm/294071
7. Thorthor 4866 Vortex IV http://www.3dmark.com/fs/1262196
8. andjon838 4753 Vortex III http://www.3dmark.com/3dm/918671
9. Cricky 4751 http://www.3dmark.com/3dm/1992419
10. keynes 4725 http://www.3dmark.com/fs/547507
10= jacktimson 4725 http://www.3dmark.com/3dm/982095
ThoRob
https://www.3dmark.com/3dm/70929558
How does this compare for a low/mid range system?
CaseFRACTAL FOCUS G BLACK GAMING CASE (Window)
Processor (CPU)Intel® Core™ i5 Six Core Processor i5-12400F (2.5GHz) 18MB Cache
MotherboardASUS® PRIME Z690-P D4 (LGA1700, USB 3.2, PCIe 5.0) - ARGB Ready
Graphics Card8gb NVIDIA GEFORCE RTX 3060 Ti - HDMI, DP, LHR
1st Storage DriveNOT REQUIRED
1st M.2 SSD Drive1TB INTEL® 670p M.2 NVMe PCIe SSD (up to 3500MB/sR | 2500MB/sW)
DVD/BLU-RAY DriveNOT REQUIRED
Power SupplyCORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor CoolingPCS FrostFlow 150 Series High Performance CPU Cooler
2nd top in the bracket for those components in the results table so I would say that's definitely a good result :)
B4zookaw
My own result: https://www.3dmark.com/3dm/70960481?
8GB NVIDIA GEFORCE RTX 3070 Ti - HDMI, DP, LHR
CORSAIR 750W RMX SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Corsair iCUE H150i ELITE CAPELLIX RGB Hydro Series High Performance CPU Cooler
Funnily enough, I had a 3dmark account from years ago and it shows my score of 5752 with a ATI Radeon X800 XT(1x) and Intel(R) Pentium(R) 4 CPU 3.40GHz 🤣 https://www.3dmark.com/3dm05/1125858
A bit of an upgrade from that system I think.....
You should update the 3DMark software to the latest. I think you're around 1000 points down but it's difficult to compare as the versions are different.
There's not a lot in it but there's definitely something that could be tweaked :)
Mmm, thought I had the latest version. Does steam not push updates automatically?
If it's switched on... yes, it definitely should. With programs I think it's less forceful though.
If you click your result you'll see the note that says you're not using the latest version so it's not a verified run for the hall of fame.
B4zookaw
Yep, saw that. Just struggling to see how I can update 3DMark. I guess some googling is required....
If you go into steam (If that's where you got it) you should be able to check for updates in the program information window.
B4zookaw
I reinstalled today, so I assume this version is the latest and therefore what I'm running?
I removed the Steam version and used the keys to install the direct download version instead
Just thought if I was benchmarking, then I was a bit silly to need to have Steam running in the background :cautious:
Just ran one there, lower score! :cry:
Likely something running in the background. Close all the programs that you don't need from the taskbar tray.
Your GPU ran cooler on that run and boosted a little higher so that should give you what you need to bump up the score. The CPU ran absolutely fine from the data I can see so I can only imagine it was memory interrupts that caused it (things running in the background).
Were the fans on max? GPU temps suggest they likely were but just wanted to check. Have all fans on max. GPU/CPU & case fans. Close everything you don't need, especially any browser windows, and re-run.
BT81
As I couldn't get the 3600mhz RAM to play nice with my system, I just left it at 3200mhz and added to what was there. THought I'd run the numbers again, with 32gb (I don't need it mind) compared to my original run with 16gb
And...no difference ;-)
BT81
Tried again
This time - 16GB ram running at 3600mhz and my new 4000d airflow case (replacing the NZXT H511)
Quantity of RAM doesn't have any impact on performance, you could have 128Gb in there, at the same speeds the system would perform exactly the same. There's a misconception about what RAM does in a PC.
