http://www.3dmark.com/3dm11/4374375 No where nearrrrr! Can anyone tell me why my 3570k isn't showing up as 4.3GHz??
Yeah, under load its at 4.3 and when i go into bios all the relevant settings are there. I did use the Autotuner function on the Mobo though.
http://www.3dmark.com/3dm11/4378574 Just reran with a slight tweak on my 660, slightly better, but as you can see it now won't even read the cpu freq. or the Ram at all... I think the overclock is set up correct to be honest tom, when i prime'd for a while and check cpu-z indicates 4.3. Not a biggy, just wana see if i can creep into P9000 mark.
What version of 3dmark though? wouldn't that make result different and therefore not balanced? I've upped the core clock to 1106 (+100) and the memory is up 300mhz. still testing whether i can go further or not.
I would advice not to change the core clock and memory since you could void your warranty if there are any issues with your gpu. I think I had some issues with 3Dmark11 and I had to repair/reinstall the application.
New 3D Mark 11 score: P13292 - http://www.3dmark.com/3dm11/4436146
Huge thanks to Buzz for his help with overclocking and enabling my HD 4000 onboard graphics to aid my 670s. Going back to stock speed now!![]()
I'm not sure exactly how, Buzz could tell you. I think it's something called Lucid Virtue which you need to download and also enable it in the BIOS somewhere.
Correct. You need to enable It in BIOS and LucidVirtue. You then need to install the Igpu drivers and lucid software.
Thats you done. You should now have your intel and dedicated gpu show up in device manager, and Lucid Virtue running.
I have been trying for a fairly long while now... i can't execute 3dmark with virtualisation/hyperformance/virtualvsync enabled
