Honestly. The people here have been amazing. Wish I has asked here first before ordering first time round
why the power supply change?Looks like a great build to me! I agree with @Nursemorph about going with the H100i CPU cooler, if you're not a fan of the RGB it can always be turned off. I'd also advise on upgrading to the RMx 850W for about £25 when it comes back on the 10th, otherwise you're onto a complete winner. Make sure you post some pics in SHOW OFF YOUR NEW COMPUTER! when it arrives!
The RMx units are better quality units so will last longer than the TXm unit which is impoartant if you plan to keep the PC for a long time. I believe there were also some issues with the TXm 550's and 650's last year. I've just realised that the RM850 is back in stock so that could be another option for £10 less than the RMxwhy the power supply change?
Item 2 | Change to [CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET] from [CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET] |
Item 3 | Change to [Corsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler] from [Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans] |
Looks good! You've got a great system there!
Item 2 Change to [CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET] from [CORSAIR 750W TXm SERIES™ SEMI-MODULAR 80 PLUS® GOLD, ULTRA QUIET] Item 3 Change to [Corsair H115i RGB PLATINUM Hydro Series High Performance CPU Cooler] from [Corsair H100x Hydro Cooler w/ PCS Ultra Quiet Fans]
