Yui-Hirasawa
This is the wonderful cleaning that they have done according to them, they have not even bothered to fit the worn screws !!!!
Did you ask them to clean it? Did PCS say that they'd cleaned it?This is the wonderful cleaning that they have done according to them, they have not even bothered to fit the worn screws !!!!
For starters, it does not say anything that they have done to solve the temperature ... And by email the only thing they told me was that it had dust and they had cleaned and changed the thermal paste, and that the temperatures had dropped between 5-7ºC (99 - 7 = 92 WOW!).Ahora he completado el RMA en su sistema. Después de recibir su sistema comencé a confirmar y aislar los problemas dentro de su sistema. Aisé las fallas en la placa base y el cable LED FFC frontal. He reemplazado estos para usted bajo su garantía y confirmó que los problemas habían sido resueltos. Estremos su sistema en una prueba de esfuerzo de carga completa durante la noche para asegurarse de que no había otras fallas dentro de su sistema. Estas pruebas pasaron y ahora estoy feliz de que su sistema sea devuelto a usted. Sentimos mucho que hayas tenido que devolvernos el ordenador. Esperamos que no tengas más problemas.
You chose not to answer the questions I asked so all I can advise is that you complain to PCS if you feel the RMA didn't solve the problem you reported. There is nothing that anyone on here can do to help you I'm afraid.I leave here the part they sent me:
The other problem was that the usb 2.0 made bad contact according to the position and swore that it remains exactly the same ...
The pieces that have changed:
When I have downloaded the games, I will test while playing but, just turn on the computer and without doing anything it is at 70ºC ... The sooner I was at 40-50ºC and browsing and with many and when I say many tabs it stayed at 70-70ºC ...
Another important point is that I have always had undervolt done, -0.130v and the cpu is 50W. How is it possible that they, who supposedly have tried it without undervolt, have been able to take it for granted ... Because if I remove the undervolt right now, the temperatures will rise 5ºC more ...
I am really very, very unhappy with pspecialist, a month wasted in every way and they send it to me just the same, someone tell me that those fans are clean ... someone explain to me why they haven't even changed the refrigeration when the GPU went to 800Mhz ... someone explain it to me, they haven't even bothered to change the sticker on the back of the chassis that was melted from the temperatures ...
What do you want me to answer, read the thread and you will know.You chose not to answer the questions I asked so all I can advise is that you complain to PCS if you feel the RMA didn't solve the problem you reported. There is nothing that anyone on here can do to help you I'm afraid.
Do you honestly think that a response like that is going to make people want to help you?What do you want me to answer, read the thread and you will know.
... A battery that I have not used more than 15 times and it is swollen and if I want to change it it is 67 €, everything is correct ...
I personally agree with all of this. It was clear from the outset that the problems were caused by not properly maintaining the chassis, the dust was particularly bad, and very likely should have been repasted a few times over the past couple of years.I'm getting the impression this thread isn't really going to get anywhere to be honest. I have my own thoughts on all of this, as I'm sure everyone does, happy to leave it open for the more active participants to decide but just giving my opinion.
I firmly believe there are unreasonable expectations here and no amount of insight or guidance is going to appease the situation.
I don't think the forum participants can guide, help or support any more than has been given already.
