ANOTHER problem - VERY annoying
Omnirat
I rang them up twice about a problem, they sent out a new GFX card, now I am having the same problem, I get blue-screens while playing games, PC restarts, then I browse the net and the browsers crash constantly, then I get more blue-screens, I am wondering if it is too late to get a refund, after all I spent ALL my wages on a computer for gaming and I can't even do that, the money would be better spent on socializing etc, this was a big waste, I don't want to be spending my free time trying to fix a computer!
This is the problem details when programs start to crash CONSTANTLY!
Problem signature:
Problem Event Name: APPCRASH
Application Name: vlc.exe
Application Version: 1.1.11.0
Application Timestamp: 4e1edf37
Fault Module Name: vlc.exe
Fault Module Version: 1.1.11.0
Fault Module Timestamp: 4e1edf37
Exception Code: c0000005
Exception Offset: 00001883
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: b1b6
Additional Information 2: b1b6ef3f6268a9fe6b9ab84264199e09
Additional Information 3: 4047
Additional Information 4: 40475f1dc8d447afba13fc883b87a936
This is not the BSoD error though, this is a separate one.
vanthus
Member Resting in Peace
This looks like a problem with VLC media player,
you may have other problems,but uninstall VLC media player if you have it installed & see how it goes.
Some malware camouflage themselves as vlc.exe though so run malwarebytes &/or antivirus scan.
thexcal
Rage!!!
I have just given up on my new Pc...Getting to the point that i hate the thing cos of it's **** GPU...
NMEBowen
Master Poster
looks more like issues with software rather than hardware so i wouldnt think you would get a refund if that is the case.
Maybe try reinstalling windows, dont download or look at any websites untilll you have a antivirus and malware protection fitted id recommend avira and dont download anything else except driver updates and windows updates and whatever you do dont use any games unless there on official disks or on steam if your still getting bluescreens then it has to be hardware, but atleast this way you can be sure.
NMEBowen
Master Poster
and thexcal i have a palit 3gb gtx 580 and its a dream no problems atall so you cant call it a **** gpu as 90% of the hardcore gaming comunity rate it as the best gpu on the market.
thexcal
well i got a **** one in 100 one 580...i get blue-screens all the time lag 10fps on Facking minecraft FFS...tell me 90% of gamers want that!!!Its starting to **** me off...i did pay 2k for this thing...
edit:100fps on minecraft not 10.
Fear
1. If you have a problem why not start your own thread instead of hi-jacking this 1.
2. If you don't give people the info they ask you for they can't help you.
3. If your game is running at 100FPS then the only lag you are getting is the internet/server your on and nothing to do with the GPU.
NMEBowen
Master Poster
winds me up the fact alot of people get blue screens and automatically think something is wrong with the pc and the supplier (PCS) are to fault. The majority of blue screens are software related and are down to people messing around either playing with settings when they dont know what they are doing or messing drivers and updates. There is no need to come onto the forums and start bad mouthing PCS or their Products if you act civilised and descride the problem and what you may have done to ba**s it up then you will get a solution. If you just come on here saying its crap and you give up on the 500-3000 pound product you have purchased you tend to seem imature and unworthy of the kind people who post on here`s time. So please may we return to the original thread and hopefully solve this person`s problem calmy and without the childish critasism.
Omnirat as i suggested i recommend you do one last reinstall of windows without any external hhd`s or backup drives attached just a clean boot drive once it has completed install the updates then use a reputable security suite (as i suggested avira is nice and simple just click free version on www.avira.com) install and update security suite then try some games from original cd or steam no dodgy sotware. If then you still get bluescreens and resets the hardware must be at fault and you may well indeed be able to get a refund if you are not happy with a RMA and your pc back. P.S. just thought before you give up you could also try updating your motherboard drivers.
Maestro
you have already highlighted the problem yourself. the source of the crash you posted was vlc media palyer. While im not saying this is the root cause of all problems, before you start ranting on here, try using the forums to get a bit of help. Tell us what you spec is, what you have tried already, etc.
I wold sugget, given that the last crash was almost entirely down to a software problem, that you at least conduct a re-install of the os and drivers.
Omnirat
It's not a problem with VLC, that 'APPCRASH' error I get all the time, for example I am using Google Chrome, it will crash constantly and I will get that error and the same with games, or a blue-screen, I have re-installed windows before and the same thing happens, my drivers are all up to date, I haven't changed anything manually and the CPU isn't overheating or being stressed, and I have a reputable security suite.
I am entitled to rant a little when I've paid out ALL of my money on what I hoped to be a good PC.
I did find this on my PC that I got told I shouldn't be able to see...
M3aaaq
xcal.. minecraft uses nothing of the gpu it's mostly cpu/ram based.. i have sli palit 580's and i run at 150-200 besides.. you can't even notice it if it's above 60
Frenchy
tpo answer a couple of questions. To the OP, the system reserved drive sometimes shows up in windows 7, its nothing to worry about, mine tends to show up when I plug an external drive in. Technically it shouldnt show up, but as far as Ive read its not a problem if it does.
To M3aaaq, dont have a go at someone like this, it makes you just as bad as the original ranter. Just because you know that minecraft isnt GPU intense doesnt mean others do.
The reason minecraft is lagging is almost certainly due to internet connection. Minecraft is written in Java which really isnt very good for large scale games, and although it should be perfectly fine, it is a beta, there are bugs in the game and it isnt fully optimised yet, this can cause slow down from time to time. Its probably not (although I cant say for certain) a graphics card problem, especially as it seems you suggest its running at 100fps.
thexcal
i have a i7 and 16gb of ram i think that will work and i know its the gpu keep getting error 116
vanthus
Omnirat,System reserved shouldn't be showing there,nor should it have a drive letter,
but it's unlikely to be causing the problem you're having.
System reserved is for use with bitlocker & boot recovery options.
It can be hidden through disk management,but ther's an outside chance that would make your computer unbootable,
so I dont recommend it.
Like Maestro suggested,I think the problem is software related & would try another reinstall,follow the instructions in the welcome booklet on how to do a clean install,making sure you delete the drive,this should solve any software problems & install the system reserved partition as it should be.
There are other things you could try first,
Try running the performance trouble shooter to see if programs are running in the background,one of which might be causing the problem.Open the Performance troubleshooter by clicking the Start button/Control Panel/all control panel items/troubleshooter, and then click Troubleshooting. Under System and Security, click Check for performance issues.
2 Uninstal VLC player.
3 run malwarebytes,
4 run the registry option in ccleaner,making a system restore point first.
Omnirat
Oh look, same error, different program!
It happens with EVERY program.
Though it was a good 6 minutes of gaming I must admit, I guess it must be a new feature with 'top end' gaming computers so that the user doesn't spend too long on it.
M3aaaq
frenchy & xcal.. sorry for my post
anyways.. are you using a texture pack? if so it could decrease the fps because minecraft uses more ram and it only uses up to 1gb at default so 16gb ram doesn't really matter
