Another hot laptop ( 15" Optimus )
_james
Chassis & DisplayOptimus Series: 15.6" Matte 4K IPS LED Widescreen (3840x2160)
Processor (CPU)Intel® Core™ i7 Quad Core Processor 7700HQ (2.8GHz, 3.8GHz Turbo)
Memory (RAM)8GB Corsair 2133MHz SODIMM DDR4 (1 x 8GB)
Change to: 32GB Corsair 2400MHz SODIMM DDR4 (2 x 16GB)
Graphics CardNVIDIA® GeForce® GTX 1050 Ti - 4.0GB GDDR5 Video RAM - DirectX® 12.1
1st Storage Drive2TB SEAGATE FIRECUDA 2.5" SSHD - UP TO 5X FASTER THAN HDD!
Memory Card ReaderIntegrated 6 in 1 Card Reader (SD /Mini SD/ SDHC / SDXC / MMC / RSMMC)
AC Adaptor1 x 120W AC Adaptor
BatteryOptimus VIII Series 6 Cell Lithium Ion Battery
Power Cable1 x 1 Metre Cloverleaf UK Power Cable
Thermal PasteCOOLER MASTER MASTERGEL MAKER THERMAL COMPOUND
Dispatch date: 23-04-2018
Its never been quiet but it seems to be noisy most of the time and it is hitting thermal throttling often. Should I take to a shop to get regreased and if so what would pcspecialists recommend, is it covered by warranty ? if I get someone to do it does it invalidate the warranty ?
Doing a git clone.
13583
Web browser and IDE and slack and email open none doing all idling :
13584
That's much too hot, and I'd say probably out of character for the Optimus as I can't recall it being the most complained-about chassis temps-wise with the 7700HQ.
Starting with the warranty, did you get the standard 1 year one or opt for a 2 year extended one?
Have you opened the laptop up (taken the back cover off) to clean it? And carefully cleaned/dusted the heat sinks / exchangers and fans?
If it's the 2 year one, contact PCS and they may well be happy to RMA it and get it sorted for you without you needing to pay anything.
If it's out of warranty (or indeed even if it is in warranty but you prefer not to send it back) you could perform a repaste yourself. There are a lot of guides online and some users here may be happy suggesting some.
Sending the laptop to a third party repair shop could affect the warranty and/or, potentially, PCS's willingness to perform out of warranty repairs, if there is a fault down the line they feel was caused by another company botching the job. So you should at least explore other options before going down that route.
_james
Thanks for the reply. I added an m2.NVMe after a couple of months and it looked ok. I ended up buying a laptop cooler pad in July of 2018.
Well it's out of parts warranty with PCS, but they do offer lifetime tech support and labour's obviously still covered.
I'd probably start with a clean and a repaste, DIY, and see how I got on. And check the obvious things like all the fans are actually spinning... the heatpipes seem to sit properly... etc
