Advice/opinions on new gaming PC please
MicZel
Looking for a much improved gaming pc from my current PCS pre built 2070s/i7. My budget is around £3500 mark give or take a couple of hundred. Would be mainly used for DCS VR/MSFS VR and fps. I have an AOC 34" CU34G2X monitor ?3440 x 1440 144hz (not sure if my current system does it full justice?)
I've only picked the 5000T case as I thought it would be good for size/fitting of components and a 4gb hard drive as extra spare storage but not sure if these are both a bit unnecessary (4gb wasn't much more expensive than 2gb!) I've never built a PC before so any advice from the vast experience here would be greatly appreciated.
CORSAIR iCUE 5000T RGB MID TOWER GAMING CASE
GIGABYTE X670 AORUS ELITE AX (WIFI 6E, USB 3.2, PCIe 5.0) - ARGB Ready!
64GB Corsair VENGEANCE RGB DDR5 5600MHz (2 x 32GB) AMD
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP
4TB CORSAIR MP600 PRO NVMe PCIe M.2 SSD (up to 7000 MB/R, 6850 MB/W)
CORSAIR 1200W RMx SHIFT SERIES™ MODULAR 80 PLUS GOLD, ULTRA QUIET
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler
ONBOARD 2.5Gbe LAN PORT
Standard Build - Approximately 9 to 12 working days
Price: £3,679.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/VmVh9EAHcE/
MicZel
Think the current case is too small. It's an i7 9700 2070s 32gb ram, an older asus motherboard. Guessing I'd probably have to pretty much change most in order to cater for a 4090. Was going to give pc to my son and get a new one. Get the best I can/need before budget gets used for something else!
....PSU Corsair VS-550, 550 W.
upgraded to 32gb ram (max apparently) and added 2tb ssd card.
....currently using a quest 2 with virtual desktop but might upgrade to quest 3 if reviews are good enough. I'm also using (trying to use!🙄) a yaw2 pro 3dof motion sim chair if that is of help/has an impact on build?
MicZel
Little more info on current spec -
Asus prime H310-Plus R2 mother board
2 x 16gb 3600mhz ddr4
Mostly play flight/racing sims in VR
PC VR games (half life Alex etc)
Other games played would be Squad,
Hell Let Loose, Pubg with monitor.
Budget - would like to keep below £3800 if possible
Hope this helps
sck451
Yeah, I don't reckon it's worth upgrading that system. Sadly not very well specced for upgrades. But I'm sure your son will enjoy it.
First, a machine of this budget is not value for money. Anything over £2500 is questionable on that front. On the other hand, it will be awesome.
Second, you can save some money and not lose performance.
Third, your monitor will not get the best out of this system. MSFS in VR totally will, but your monitor is fine, but unremarkable, next to a system that's about as good as money can buy!
CORSAIR iCUE 5000X RGB MID TOWER GAMING CASE Same size case, £100 cheaper, just as good looking
AMD Ryzen 7 7800X3D Eight Core CPU (4.2GHz-5.0GHz/104MB w/3D V-CACHE/AM5) For MSFS, a case could be made for the 7950X3D
ASUS® TUF GAMING B650-PLUS WIFI (DDR5, USB 3.2, 6Gb/s) No need for the high-end motherboard: gains you nothing
32GB Corsair VENGEANCE RGB DDR5 6000MHz (2 x 16GB) Less RAM but faster is the way for the best performance
24GB NVIDIA GEFORCE RTX 4090 - HDMI, DP For top-end gaming, there's nothing better
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) I'd prefer this to the Samsung
2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE The 4TB drive isn't great: it's very slow at 5400RPM
CORSAIR iCUE H150i ELITE LCD XT RGB CPU Cooler Total overkill, but will be pretty in the 5000X
NO ANTI-VIRUS SOFTWARE Don't use Norton: it's rubbish!
Price: £3,380.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/aztrtRBaDF/
MicZel
Thanks for your advice/suggestions, that's great thanks. Before i order can I clarify a couple of things please as my knowledge in this field is pretty basic.
The motherboard you suggested is that "futureproof" as in not like my current one! Will I be able to upgrade it if necessary in years to come?
Will 32gb ram be enough for dcs, sim rig and a sim shaker running at the same time? If so, would I still be able to upgrade to 64gb in future if it is necessary?
sck451
The motherboard will be fine. There could be an argument for going for the Tuf X670E board if you see a need for huge amounts of very fast connectivity (PCIe for storage or USB) or you want the maximum possible safeguard against future compatibility, but it probably makes no difference.
I don't know about your specific setup. You would need to ask someone who actually runs a similar setup and see their memory use. If you need 64GB you'll probably need to replace the existing memory. I wouldn't compromise and go for slower memory: you could order your own kit from elsewhere and go for a cheap kit that you're happy to sacrifice if you're sure you need that much
MicZel
Have gone with all recommendations with exception of I've upgraded to Asus x670e motherboard. Wanted to be sure its futureproof. Managed to find a £30 promo code too so not a big increase.👌 Thanks for all the advice and suggestions it's really appreciated.
Just the wait now!
