Advice on specs needed
MarkPoole1
I’d probably just go with an extra 3 to be honest, they will go at the front and look similar to the 5000X
Ok thank you for that might give that case a closer look as with it not having a tempered glass front it a big plus.
Do you have any advice regarding the ASUS PCE-AX58BT 802.11AX is it much better than the INTEL® WI-FI 6 AX200 for the price difference?
Ash_
Master Poster
In all honesty, i have an AX200 but i don’t use wifi or bluetooth. Most on here would say the Asus isn’t worth it.
Also with the 5000 cases, you can actually buy the glass/airflow panels and swap them out, i like the look of the airflow case anyway with lights behind.
MarkPoole1
I use both wifi an bluetooth but if there's not much difference for the price i will just stick to the AX200 an grab a bluetooth usb stick.
Yes just seen you can change the fronts on the 5000 thanks so much for your help.
