Fractal Meshify C
How come this has no fans. It doesn't mention top fan support?
Fractal Meshify C
No idea why it isn't mentioned on the PCS site, but it has space for three 120mm fans in the front, two on top and one on the back, so it can fit a 240mm AIO on the top or a 360mm one on the front. I believe it has one front and one exhaust as standard.How come this has no fans. It doesn't mention top fan support?
Where are you reading that? In the specs it's listed as having 2 front fans and one rear fan. You can see the rear fan in the first pic.How come this has no fans. It doesn't mention top fan support?
Apologies I over looked the fan at the back the first time. It doesn't mention top fan support in the description.Where are you reading that? In the specs it's listed as having 2 front fans and one rear fan. You can see the rear fan in the first pic.
Or are you confusing fans with RGB?
I can definitely confirm, do not buy silence cases. They are horrible for cooling and in the end fans have to be set to higher RPM resulting for more noise anyway.All the mid-range cases are fine for your uses as long as you avoid the quiet ones. Anything with mesh on the front will have you covered. I believe all the mesh cases support roof mounting for the AIO. I wouldn't get too concerned about it though. Top mount doesn't perform as well for your CPU. It's swings and roundabouts as the difference is minimal.
It's difficult at times not to go down a rabbit hole, the reason we aren't making much of a deal of the top mount query is that there isn't really much to advise/consider.
If you really, REALLY, want to ensure top mount. Give PCS a call with your request and they will advise a combo that suits perfectly. Otherwise I wouldn't want to state anything as fact and then it turned out that PCS installed it on the front anyway.
That mash is going to make a real mess of the inside of the case, especially if it is served with gravy 🤣If you are choosing case, buy stuff with mash in front as a general rule of thumb, you cant really go wrong with that.
crap xD in my defense English is not my native languageThat mash is going to make a real mess of the inside of the case, especially if it is served with gravy 🤣
My Danish is not good at all, although I used to be able to count and manage a few phrases in Norwegian, I was led to believe that Norwegians and Danish were quite similar, but I might be mistaken, I was pretty fluent in French, but am now very rusty and my German is even rustier. I did also learn Italian and Cantonese at evening classes, but nowadays the most translation I need is usually from Doric (north east dialect of Scots) into English.you have not heard me attempting to talk in danish lol xD i might as well be on the level of bigfoot danish xD
You didn’t adopt this approach, did you?I have been laughed at in a shop in Italy. I don’t know what I said, but it seemed hilarious. Perhaps I mixed up some words.
I can manage some American, and a smattering of Australian.................I can speak Yeti and Sasquatch fluently, but my Snowman is abominable 🤣
Well I only been learning for half a year, and am only in this country for 15 months. So getting there slowly xDMy Danish is not good at all, although I used to be able to count and manage a few phrases in Norwegian, I was led to believe that Norwegians and Danish were quite similar, but I might be mistaken, I was pretty fluent in French, but am now very rusty and my German is even rustier. I did also learn Italian and Cantonese at evening classes, but nowadays the most translation I need is usually from Doric (north east dialect of Scots) into English.
I really shouldn’t make fun of language, especially on a forum with many non-English speakers (although most foreigners speak better English than the natives). In my defence, I have been laughed at in a shop in Italy. I don’t know what I said, but it seemed hilarious. Perhaps I mixed up some words.
The irony of supply and demand, I guess more people are opting for the RGB RAM hence bringing prices down.I changed the RAM to the PRO RGB 3200 and it was cheaper?
Thanks for the tip. I was in a pickle last night deciding which one to go for, I have taken the advise and dropped it down to the H100i.I would personally drop the cooler down to the H100i which is still overpowered for that chip, but nice and quiet.
