Advice needed! Thanks.
Gorman
Would this happen to have anything to do with why when I forced VSYNC on, in my nvidia control panel, fraps recorded my screen much much better with NO lag, than ever before? GPU was outputting 60fps max and had way more free time to deal with the screen capture maybe?
EDIT: Lewwoo, you wont notice the diff, as the monitor will display 60 frames per second, even though the GPU may be sending out many many more.
When the monitor and GPU are working in sync, everything seems smoother, although vsync can cause input lag as frames are buffered.
For Cod4 and many games on the quake engine, there are special FPS setting which improve fire rate of guns, hit registration etc. Check out this very intereesting article http://bashandslash.com/index.php?Itemid=63&id=51&option=com_content&task=view
Here the article is talking about a variety of things, none of which really relate to the fps your monitor can display. This Quake engine sweet spot is very very old and i prefer to get a balance between smooth gameplay and page tearing, i really really hate page tearing:
Also as a foot note, CoD4 is a long way off being a pure Quake 3 engine, its been modded far too much to go off that article alone:
Game engine
The visuals featured in Modern Warfare were highly praised.
Call of Duty 4: Modern Warfare runs on the IW engine, featuring true world-dynamic lighting, HDR lighting effects, dynamic shadows and depth of field.[13] Bullet penetration is calculated by the engine, taking into account factors such as surface type and entity thickness. The game runs in a native resolution of 600p on the Xbox 360 and PS3.[14]
Certain objects, such as cars and some buildings, are destructible. This makes distinguishing cover from concealment important, as the protection provided by objects such as wooden fences and thin walls do not completely protect players from harm. Bullet stopping power is decreased after penetrating an object, and the decrease is dependent on the thickness and surface type of the object. The game makes use of a dynamic physics engine, not implemented in previous Call of Duty titles. Death animations are a combination of pre-set animations and ragdoll physics. Console versions of Call of Duty 4: Modern Warfare run at a consistent 60 frames per second, and the Wii version runs at 30 frames per second.[13] Code was included to determine spawning points based on the nearby weapons and the relationship between enemy positions and line of sight to the points. The various criteria are meant to minimize players dying immediately after rejoining a match, or being "spawn-killed" due to players simply waiting for others to "respawn".[10]
The game engine has also been used for the development of two other Activision games. An enhanced version of the original engine was used in Call of Duty: World at War, the fifth installment in the Call of Duty series after Call of Duty 4,[15] while a slightly altered version has been used for the James Bond video game Quantum of Solace.[16]
http://en.wikipedia.org/wiki/Cod4
The IW Engine is a game engine developed by Infinity Ward and was used in the highly successful Call of Duty series. The engine was first used with Call of Duty 2 in 2005 under a proprietary license, as well as using the source code of id Tech 3[1] released under the GNU General Public License (version 2) the same year. An Infinity Ward proprietary engine was once again used in Call of Duty 4: Modern Warfare. The engine did not have an official name until IGN was told at the E3 2009 by the studio that Call of Duty: Modern Warfare 2 would run on the "IW 4.0 engine".[2] Enhanced versions of the engine were used by Treyarch in their Call of Duty games (after Call of Duty 4)[3] and Quantum of Solace.[4]
http://en.wikipedia.org/wiki/IW_engine
Tom DWC
I prefer to get a balance between smooth gameplay and page tearing, i really really hate page tearing.
You wouldn't want an Xbox 360 then lol, quite a few new games are being released without any kind of V-Sync enabled. I'd take inferior but smooth graphics over superior with screen tearing any day of the week.
Gorman
Thats what i mean, i hate page tearing and try to balance my systems to prevent it, be it through Vsync or other methods. Inferior graphics are going to make page tearing even worse as it occure when your GPU is throwing out frames faster than your monitor can support!
Tom DWC
I agree. It really is horrible and ruins what would otherwise be an immersive experience. When I say I'd take inferior graphics, I mean if I had a choice between a setup with mediocre graphical quality but a steady frame rate and no tearing, I would choose that over high quality graphics but with an inconsistent FPS and jaggies.
lewwoo
The sweet spot still applies in COD4. As the article says, 'you feel like your floating' when you go up from say the default capped at 85 to 125. Anyways, I know you say my screen won't show above 60 fps, but it doesnt actually lock the FPS ? Also I use a graphics config in COD4 to give me better visuals/ let me jump further, so graphics aren't to important in that aspect and neither is screen tearing. However for single player games I turn the graphics right up and love the visuals.
Gorman
Thats right, with vsync off the GPU will spit out as many frames as it can unless the game has a cap which your tinkering with. The monitor limit is the amount it can display, the GPU will still spit out as many as it can, theyre just lost is all. So from a perspective outside of going for the freak mutant q3 engine sweet point, the extra grunt is a bit pointless.
Man how can you play with page tearing, it makes me rage.
lewwoo
Forgot to add, thanks for your help. Very patient with me. I may just switch to my old screen if what you say is true. So everything is looking good, I will be ordering around Monday.
Gorman
This is why you see a lot of people still rocking upto the Iseries lans with huuge CRT monitors!
lewwoo
Hi guys,about to order. Anything I have missed out?
COOLERMASTER HAF 932 FULL TOWER GAMING CASE (£120)
Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost
ASUS® P7P55D-E PRO: USB 3.0, SATA 6.0GB/s, CrossFireX™ / SLI SUPPORT
768MB NVIDIA GEFORCE GTX460 GDDR5 PCI EXPRESS - DirectX® 11
2nd Graphics Card
3rd Graphics Card
NONE
NONE
2nd DVD/BLU-RAY Drive
NONE
Power Supply & Case Cooling
CORSAIR 750W PSU (TX750) 80+ ULTRA QUIET (£88)
TITAN FENRIR EXTREME DIRECT TOUCH COPPER CPU COOLER (£39)
ONBOARD 10/100/1000 GIGABIT LAN PORT
Modem
NONE, I WILL BE USING BROADBAND
Floppy Disk Drive
NONE
Firewire & Video Editing
NONE
TV Card
NONE
Monitor
22" Wide TFT Silver/Black 1920 x1080 2MS D-Sub, DVI, 21.6" Panel (£119)
2nd Monitor
NONE
DVI Cable
NONE
GeForce 3D Vision
NONE
NONE
Mouse
NONE
Speakers
NONE
NONE
Headsets (VOIP)
NONE
Surge Protection
NONE
Printer
NONE
External Hard Drive
NONE
Home Installation
NONE
Data Recovery
NONE
Standard Build - Approximately 9 to 12 working days
I am on live chat if any of the PCS reps are available.
Sleinous
2nd Graphics Card
3rd Graphics Card
NONE
NONE
NONE
Modem
Floppy Disk Drive
NONE
NONE
TV Card
NONE
Monitor
2nd Monitor
NONE
DVI Cable
NONE
GeForce 3D Vision
NONE
NONE
Mouse
NONE
Speakers
NONE
NONE
Headsets (VOIP)
NONE
Surge Protection
NONE
Printer
NONE
External Hard Drive
NONE
Home Installation
NONE
Data Recovery
NONE
Can't really find anything worth mentioning, except, obviously, if you had the extra budget, go for the 1GB GTX 460s, because, bear in mind, you will ONLY get 768mb of vid mem, not 1536mb. So, if you got the 1GB ones, you'd get 1GB of vid mem, only saying this because you MAY start to struggle with that 768mb when games start to say recommended 1GB vram etc etc :)
lewwoo
So I have just done a sub order changing to a I7. However it says Change to Intel® Core™i7-870 Quad Core (2.93GHz, 8MB Cache) + Turbo Boost from Intel® Core™i5-760 Quad Core (2.80GHz, 8MB Cache) + Turbo Boost. That reads as though I am being charged for 2 things.
lewwoo
