Advice needed for new machine for work
Paulcarp
Hello All. Hope someone can help here. I’m looking to upgrade my machine for work purposes. It will be a real graphics jack-of-all trades, and I use mainly 3ds max, C4D, blender Modelling animating and rendering both cpu and gpu) and Adobe after effects and photoshop and ZBrush and I’m just starting to use unreal engine. (A little gaming but not much) and am wondering if either of these specs are good or if anyone has better recommendations. They're both coming in at £3.5 K though I do have more in the budget if needed about 4.5-5k max.
It’s been a while since Ive had to configure a new pc so am a bit lost. Intel or AMD? How many fans?
Monitor: dual Dell P2415Q 24" Ultra HD Monitor though one has just died
Option 1
FRACTAL NORTH TG XL GAMING CASE (BLACK)
Intel® Core™ i9 24-Core Processor i9-14900KF (Up to 6.0GHz) 36MB Cache
ASUS® PROART Z790-CREATOR WIFI (LGA1700, DDR5, PCIe 5.0, Wi-Fi 6E, 1 x 10GbE)
96GB Corsair VENGEANCE DDR5 5200MHz CL38 (4 x 24GB)
16GB ZOTAC GEFORCE RTX 4080 SUPER TRINITY BLACK EDITION - HDMI, 3 x DP
16TB SEAGATE IRONWOLF PRO 3.5", 7200 RPM 256MB CACHE
PCS FrostFlow 150 Series High Performance CPU Cooler
2 x 120mm Thermaltake TOUGHFAN 12 Case Fans
ONBOARD LAN PORT
Microsoft® Edge
Price: £3,454.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/Intel-z790-workstation/90z23D9wGX/
Option 2
AMD Ryzen 9 9950X 16 Core CPU (4.3GHz-5.7GHz/80MB CACHE/AM5)
ASUS® ROG CROSSHAIR X870E HERO (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7)
64GB Corsair VENGEANCE RGB DDR5 5600MHz CL40 (4 x 16GB)
PCS FrostFlow 240 Series ARGB High Performance Liquid Cooler
ONBOARD 2.5Gbe LAN PORT
Microsoft® Edge
Price: £3,503.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-workstation/B5Zc95ZAb2/
AMD is the only option
Paulcarp
Thanks. I thought I had read that there was some benefit to using intel over amd’s with some 3d programmes. But with the over heating and power consumption issues and the reports of bugginess the decision is easy to make.
Nursemorph
I'm not an expert with things like Blender etc nor am I sure how much the new GPUs offer over the previous gen...will need someone else to weigh in on it. With that in mind, I've adjusted the spec to create something more balanced (some options you wouldn't have seen when you drew up your spec as I have done it on a different configurator):
FRACTAL NORTH TG XL GAMING CASE (WHITE)
GIGABYTE X870 EAGLE WIFI7 (AM5, DDR5, M.2 PCIe 5.0, Wi-Fi 7) - I don't see the benefit of the Crosshair, given it's huge price. Gigabyte boards are better than Asus these days. If you want Asus, then maybe go to the Strix.
64GB Corsair VENGEANCE DDR5 6000MHz CL40 (2 x 32GB) KIT - 2sticks is better for performance than 4. WOuld prefer lower latency but 40 is the lowest for 64GB.
16GB PALIT GEFORCE RTX 5080 GAMEROCK - HDMI, 3 x DP - Newer generation. As mentioned, not sure how much better it is for editing etc.
512GB SOLIDIGM P44 PRO GEN 4 M.2 NVMe PCIe SSD (up to 7000MB/sR, 4700MB/sW) - Better to have a small Windows drive.
4TB CORSAIR CORE XT MP600 NVMe PCIe M.2 SSD (up to 5000 MB/R, 4400 MB/W) - Ensures you still have plenty of fast storage
CORSAIR 1000W RMx SERIES™ ATX 3.1, MODULAR, CYBENETICS GOLD - Has extra headroom for possible GPU upgrades later on in the PCs life, maybe consider the 1200w as the budget is there
CORSAIR ICUE LINK TITAN 360 RX RGB HIGH PERFORMANCE CPU COOLER - Vastly superior cooler which will be need given your uses
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING - No need as the cooler comes with machine applied paste already
NO ANTI-VIRUS SOFTWARE - Don't include Norton, it's pretty much garbage these days
Firefox™
3 Year Silver Warranty (1 Year Collect & Return, 1 Year Parts, 3 Year Labour) - Minimum warranty really...£5 for an extra 6 months of C&R
Price: £3,462.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/cUxGDBRJRr/
Paulcarp
Nice one. Thank you! Will deffo amend to take those factors into consideration. And thanks for the heads up on the motherboard and cooler.
