It’s pretty much the same as a 3090 for gaming, so around 10% improvement over the 3080.I may be mistaken, but I seem to recall a thread bemoaning the value of the 3080TI. It said that there was only a small performance gain for a lot of money. Others may be able to point you to the relevant thread or give you an alternative opinion.
Personally I would have kept the HDD over the SSD assuming its for general storage and nothing that requires the speed of an SSDHi guys, so this is it..... the final build hopefully. Thanks again to everyone who helped and also to PCS who were really helpful with me this morning transferring me from an Intel build to AMD. So excited for this PC now!!
Some notable changes I made were adding an additional case fan to provide exhaust at the rear of the 5000x case, replace the previous hdd with a SATA ssd for general file storage and as per recommendation to a 1kw PSU.
AMD Ryzen 9 5950X 16 Core CPU (3.4GHz-4.9GHz/72MB CACHE/AM4)
ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
64GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (4 x 16GB)
12GB NVIDIA GEFORCE RTX 3080 Ti - HDMI, DP
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
1x 120mm Thermaltake TOUGHFAN 12 Case Fan
Welcome Book
Logo Branding
PCSpecialist Logo
It’s a lovely build. Will absolutely fly!Honestly, and it may sound pedantic, but I didn't want any hdd mechanical noise so that's what made me go for the ssd. Plenty of opportunity for expansion in the future if required but at this time a total of 3.5TB seemed plentiful.
i decided against HDD myself too. SSD is the future and they are quite more affordable nowadays. Do keep in mind one thing, SSDs need a power or they will lose data overtime. If you plan to store something long term externally, SSD is a no goHonestly, and it may sound pedantic, but I didn't want any hdd mechanical noise so that's what made me go for the ssd. Plenty of opportunity for expansion in the future if required but at this time a total of 3.5TB seemed plentiful.
Also, the main reason people still suggest HDDs over SSDs for storage is that when an SSD fails, it just fails and it’s the whole drive that dies.i decided against HDD myself too. SSD is the future and they are quite more affordable nowadays. Do keep in mind one thing, SSDs need a power or they will lose data overtime. If you plan to store something long term externally, SSD is a no go![]()
to be fair, you do get warnings for SSDs too, most if not all modern SSDs use the S.M.A.R.T system to report errorsAlso, the main reason people still suggest HDDs over SSDs for storage is that when an SSD fails, it just fails and it’s the whole drive that dies.
HDDs tend to deteriorate sector by sector so you get warning long before the drive failed and have time to replace it.
especially the samsung ones with Samsung Magician softwareto be fair, you do get warnings for SSDs too, most if not all modern SSDs use the S.M.A.R.T system to report errors
Doesn’t work though, I know from experience. It’s a brand new thing and only markers one failure type. It’s not ready for real world scenarios atm.to be fair, you do get warnings for SSDs too, most if not all modern SSDs use the S.M.A.R.T system to report errors
hm, pretty sure i seen the warning online that SSD is failing to do backup and replacement, either way, the chances this will happen are very very slim. On top of that anyone who is buying a system like that probably knows to do backups or cloud storage. Microsoft does it even itself with onedrive by defaultDoesn’t work though, I know from experience. It’s a brand new thing and only markers one failure type. It’s not ready for real world scenarios atm.
Yeah, absolutely. No matter what drive type you have, a good backup solution is a pre requisite.hm, pretty sure i seen the warning online that SSD is failing to do backup and replacement, either way, the chances this will happen are very very slim. On top of that anyone who is buying a system like that probably knows to do backups or cloud storage. Microsoft does it even itself with onedrive by default
but fair
i feel personally attacked by this comment, mods please do something with this user xD xD xDIt looks like a monster build. Now you have the fun of making multiple amendments and second guessing yourself while waiting for it to be built.
Ha ha... amazing!
at least i think by now it has everything as i want itHa ha... amazing!![]()
