Maybe go with AMD?
I noticed you’ve chosen the following:Would there be any advantage to changing the RAM configuration to 4 x 8gb Corsair VENGEANCE DDR4 3200MHz over my current 2 x16gb 32GB Corsair VENGEANCE DDR4 3200MHz
When I spec’d a similar PC I was advised to use the H115i version. Only trouble is it doesn’t fit into the 4000D case. The larger 5000D case is out of stock.
If the cooling solution you’ve selected is good enough. I will probably go for this 4000D case.
Cooling and reliability is my biggest worry.
Edit: Hang on. I just changed to the 4000D case and it didn’t flag up any issues with the 3080/3080TI and 115i cooler. Previously it wouldn’t let me combine the two due to size constraints.
But does the 870 QVO really get the ground in dirt out of your whites?I had a £30 digital voucher from Samsung due to some issues with our washing machine delivery and installations (yes that is plural) so I bought a 870 QVO SATA 2.5” SSD 2TB from Samsung Store (for my, please god, soon to belivered new pc) which was listed as £170 on their website but I got a £17 discount through my work portal and then my £30 voucher actually rocked up as £110 when I put the code in so only cost me £43 in the end!! A very happy bunny for this result!
I do indeed sirfor I, discosparta, are impressed with your bargain hunting,
i take you still have a washing machine as well
