240hz Refresh Rate Gaming?
rajadd
Hi friends,
I just bought this spec. I wanted to get your thoughts on it and whether it's powerful enough to run games in 240hz refresh rate on the Odyssey G9 QLED Dual-QHD 32:9 Gaming Monitor - https://www.samsung.com/uk/monitors...-1000r-curved-display-49-inch-lc49g95tssuxen/ ?
ALSO, is it a badass setup generally?? Thanks for your responses!!
CORSAIR CRYSTAL SERIES 680X RGB GAMING CASE
Intel® Core™ i9 Ten-Core Processor i9-10900K (3.7GHz) 20MB Cache
ASUS® ROG MAXIMUS XII HERO Wi-Fi (LGA1200, USB 3.2, CrossFireX/SLI) - ARGB Ready
10GB NVIDIA GEFORCE RTX 3080 - HDMI, DP (Delivery before Xmas not guaranteed)
2TB SAMSUNG 970 EVO PLUS M.2, PCIe NVMe (up to 3500MB/R, 3300MB/W)
LED Lighting
2x 50cm White LED Strip
Firstly, congratulations on choosing the G9, it truly is a phenomenal monitor and the 3080 is the right card to push frame rates on it.
However, I feel you’ve dropped the ball by going for an Intel build. Check out the thread below for a long list of reasons why AMD are the wise choice these days...
I (and pretty much everyone else here) would strongly recommend you cancel that order ASAP and come back for some advice 👍
As @AgentCooper says, Intel are now the weak underling with no sign of gaining traction for years to come. They're about 6 years behind the times now in basic architecture, just really poor CPU's in general.
An equivalent priced AMD chip will get you around 20% more in single threaded, and often 50% more in multithreaded, there's just absolutely no competition.
Just a further kudos on choosing the G9, it's quite simply, hands down the ultimate gaming / productivity monitor in existence imho, nothing comes close as yet, although I sincerely hope we'll be seeing more competitor products emerging at CES in January.
Hopefully the success of it has been for all to see.... it's just a thing of utter beauty!
Gavras
Master Poster
Definitely not badass.
bit like buying what you think is an M3 and finding out it’s a 320i with body kit.
Also if reordering go with for some more watts on your PSU is a good idea.
rajadd
What would make it badass?
Well here’s my suggested AMD spec...
Capture/Streaming Cards
Elgato Game Capture HD60 PRO - PCIe Card
Firefox™
Standard Build - Approximately 15 to 17 working days
Price: £2,941.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am4-gen3-pc/aZmYwE4hKz/
rajadd
Thank you for the spec!! May I ask, what's the purpose of having 2x M.2 SSD drives? Do they complement each other somehow or is the faster one meant to be where the OS is stored on? I can't see the option to assisn the OS to either M.2 when proceeding with the order.
Gavras
Master Poster
One for OS, other makes for rapid game loads.
