CraigMerrick53
Couple of minor changes I would make:
- Change the RAM for 2x8GB rather than 1x16GB. RAM is dual-channel so, while it will work with a single stick, it is designed to operate better with 2 sticks. Only £5 more
- Remove the Bullguard anti-virus. The in-built (and free) Windows Defender is just as good and doesn't cause issues like Bullguard has a history of doing
- Up the warranty to Silver for an extra £5. Better coverage for little money
Other than that, you are looking good thereGiven that they will likely install Windows on the 1TB drive (unless you specifically ask them to install it on the 250 one), a 250GB storage drive seems a bit redundant to me...if it was me, I'd up it to the 500GB version as it's only £40 or so more for double the drive space which is a bargain on a drive like the Samsung
Taking everything on board you’ve said. My only come back is I put a single 16gb Ram in just incase I wanted to increase in the future... is that not that way to go?
