1440P Build Questions
Jax
Hi Peeps, now that SpyderTracks was helpful in answering my finance questions I need some help from you experts on a build. I used to keep up with all the hardware but I haven't brought a new PC in 6 years so i'm behind these days. I want to move into a 1440p set up and wondered what people had for there's?
Looking at something that would output at least 60FPS for most modern games and if I could use some of the basic Ray Tracing elements, that would be a bonus...
* The 7800 XT (16gb) caught my eye after looking at benchmark tests online - Or is this overkill and a cheaper card would do similar results? Been 20 years since I left NVIDIA for a Radeon. (Currently got a GTX 1060 6gb)
* 16 or 32 GB DRR5 Ram? is 32 overkill or future proof as more games seem to want 16 not 8 anymore.
* Ryzen 5 7600XT
* Not sure on the motherboard TBH?
* Never tried a M.2 SSD either
* Also my last two PC's had liquid cooling but they have been nosier than I liked and I hear fans are much quieter these days than before?
Jax
So my budget is a bit more flexible due to the finance option and a build I'm currently playing around with is around £1500 (I saved some money by using my own Windows 10). Don't think I would like to go higher.
There are aspects I'm not sure about still though...
CORSAIR 3000D AIRFLOW MID TOWER GAMING CASE
AMD Ryzen 5 7600X Six Core CPU (4.7GHz-5.3GHz/38MB CACHE/AM5)
ASUS® TUF GAMING B650-PLUS WIFI (AM5, DDR5, PCIe 4.0, Wi-Fi --- Not sure about motherboards to be fair.
32GB Corsair VENGEANCE DDR5 4800MHz (2 x 16GB) KIT --- 16 OR 32GB? how much future proofing do I really need in this area?
16GB AMD RADEON™ RX 7800 XT GAMING - HDMI, DP - DX® 12 --- For 1440p with some light RT elements on some game
2TB PCS PCIe M.2 SSD (3300 MB/R, 2900 MB/W) --- Always had normal SSD but heard good things about these
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler --- How quiet is this? normally have liquid cooling but never been overly happy with it from a sound point of view with the pump noise. I hear from some that fan cooling are much better these days in this area then previously.
Could you post the full spec as detailed in the sticky post below, as it helps us assess the full build (which is important) and allows us to tweak it without having to create a whole new configuration.
You've saved a bit by using your own Windows licence, but £1400 is really 1080p territory, and 1440p is around the £1900 mark (that's with the £100 for Windows removed).
However, I would say that you'd want a smaller, but faster, primary SSD for the boot/apps/launcher drive (e.g. a 512GB Solidigm P44 Pro), and a larger, but slower, secondary 1-2TB SSD (e.g. 1-2TB Solidigm P41 Plus) for games installs as a lot of modern games require installation to an SSD to perform properly.
Is the 2TB HDD there for general storage (docs, videos, etc.) or where you hoping to use that for games too?
You've chosen very slow RAM, which would be fine for an office machine, but will reduce your gaming performance by about 10-15%. But yes, 32GB is the recommended amount nowadays.
The AK620 cooler will be fine for the 7600X.
The 7800XT GPU is perfectly fine for high raster and lower-end ray tracing at 1440p.
Case is at the very budget end of the Corsair range, so even the 4000D would be a better option, but we'd need to know your MAX budget to see if there's any point tweaking the components to suit.
If you can share the entire config including the configuration link at the bottom this will allow us to go in and suggest changes. Your unique link will always be the same, it just creates a new one each time we suggest changes.
32GB should be the standard for now. You want 6000Mhz though, 4800 is far too low end.
7800XT is decent value but it's going to tank with Raytracing on. You really want to look at a 4070 Super for this as a minimum, budget is restrictive though.
I wouldn't opt for a stand alone M2 drive and I certainly wouldn't opt for a PCS offering for the primary.
Cooler quality depends on what you spend. You need to opt for Corsair for something decent in the AIO list. The AK620 is a good cooler when paired with reasonable airflow. Not sure I would opt for the 3000D personally, it's quite small. With the lower end AMD chips the cooler will pair well though.
Jax
Thanks for the replies in particular the changes to the SSD Drive and comparing the 7800 and 4070 Super, which for around 20 quid more does seem like a better choice. I'm still trying to keep it within the 1500-1599 range including a weekend shipping (which is a must due to work) and this build is what I have.
Still some questions - I presume I shouldn't go cheaper on the motherboard and Ryzen (for example the 7600 instead of 7600 X). I'm still going back on forth on Liquid Cooling or keeping the AK620 - I have a thing about annoying noises bugging me and I would like something quiet but obiviously does the job still.
https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/SzzzFwSqnP/
Currently at Price: £1,577.00 including VAT and Delivery.
Really appreicate the input you offered earlier, thanks for that.
Don’t forget that the new AMD CPUs are due out this week, so the price of these older ones may drop, or you may be able to get a newer, faster one for the same price.
CORSAIR iCUE 4000X RGB TEMPERED GLASS MID-TOWER ATX CASE - WHITE - better case with the same white aesthetic, but better build quality and better, more controllable fans
AMD Ryzen 5 7600 Six Core CPU (4.0GHz-5.2GHz/38MB CACHE/AM5) - margin of error performance difference to the 7600X, saving used to upgrade case, RAM & PSU
32GB Corsair VENGEANCE DDR5 6000MHz (2 x 16GB) - sweet spot for AM5, and probably gains back anything lost in the CPU change
12GB NVIDIA GEFORCE RTX 4070 SUPER - HDMI, DP, LHR
Graphics Card Support Bracket
1TB SOLIDIGM P41+ GEN 4 M.2 NVMe PCIe SSD (up to 4125MB/sR, 2950MB/sW)
CORSAIR 750W RMe SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET - about the minimum I’d go, and only this low as it’s an ATX3 RMe PSU (would want 850/1000W RM ATX2 PSU)
DeepCool AK620 ZERO DARK High-Performance Dual Tower CPU Cooler- fine for this level of CPU, and a very good air cooler
ONBOARD 2.5Gbe LAN PORT
NO RECOVERY MEDIA REQUIRED
Microsoft® Edge
SATURDAY DELIVERY TO UK MAINLAND (BEFORE 2PM)
Price: £1,600.00 including VAT and Delivery
Unique URL to re-configure: https://www.pcspecialist.co.uk/saved-configurations/amd-am5-pc/qYUfTWjZzr/
Jax
I will keep an eye out for sure as I won't be ordering just yet but soon.
